help, my rear right shock smacks around and rattles after coilover install
Old Jun 6, 2004 | 12:34 AM
allmotorEG-SI's Avatar
Default help, my rear right shock smacks around and rattles after coilover install
I just got some skunk 2 coilovers from a friend and the car was fine when I first had them on. But after driving for a little while the rear right shock sounds like its smacking around inside and I can't figure out what it would be. All i can think of is the shop didn't install the rubber O-rings, or they came loose, or maybe its because they put that shock on upside down.
Old Jun 6, 2004 | 08:48 AM
stmotorsports's Avatar
Default Re: help, my rear right shock smacks around and rattles after coilover install (allmotorEG-SI)
could be upper strut mount bushings, when they get old & worn out they get real sloppy- feels like a bad shock or like you have a flat tire when you hit hard bumps or anything...
my gf had the same prob on her hatch & thats what fixed it. ThinkI need rears in my coupe too...
Old Jun 6, 2004 | 02:46 PM
IVI's Avatar
IVI
make sure the 2 top bolts are tight.
Old Jun 6, 2004 | 02:47 PM
IVI's Avatar
IVI
Default Re: help, my rear right shock smacks around and rattles after coilover install (IVI)
or why dont you take it back to the shop and tell them they messed up.
Old Jun 6, 2004 | 09:47 PM
Turns out that they forgot to put a washer on between the bolt on the top of the shock and the rubber bushing below it. That caused the bushing to eventually pop off. A 10 cent washer and 5min fixed it.
soon2b
Jan 2, 2005 08:33 AM
whizdumb
May 4, 2003 07:19 AM
lsvtec101
Mar 11, 2003 10:07 AM
baonest1
Feb 19, 2003 10:12 AM
