Odd Idleing
I am having a problem with my idleling. Car runs great when driving and I get sweet gas mileage but when I stop at a light or something the car will rev up to 1500rpm then drop down to 500rpm then jump back up to 1500 and repeat the cycle over and over again. Its not a fast jump it has a one second difference between changes. I check the fuel pressure guage when this happens and it does not move. What could cause something like this? My friends tell me that every civic they have ever owned did this and no one could tell them why. So I come to you guys. Thanks.
Aight sounds logical to be the Throttle postition Sensor. I used to have a Nissan 240zx that did the same thing. But what is an IACV and a CELs? I am not familiar with those terms.
IACV = Idle Air Control Valve
CEL = Check Engine Light
You can try and adjust the Idle Adjusting Screw right above the air intake pipe where it connects to the the throttle body. See if that helps.
What's truly amazing is that nobody has made the suggestion of a vaccuum leak
That's the first thing you should look for when you get an idle like this. It's not your TPS...that's for sure. And don't touch the screw on the throttle body. Check all of your vaccuum lines for leaks. You have no codes so it's nothing electronic.
check your throttle cable...i have had this problem before and it turned out my throttle cable was a bit too tight. So i losened it up a bit and now it idles like a dream :].
itsJDMyo
May 30, 2004 04:05 AM
