is my clutch out?! (symptoms inside)
Old Jun 6, 2004 | 12:00 AM
Jon Like Wh0a's Avatar
Default is my clutch out?! (symptoms inside)
this just happened all randomly tonight, but when i got into my car, i stalled and realized that my "catch" point was about an inch from the bottom of the clutch.
it seriously feels like the gas pedal until about hte last 2 inches of the clutch. maybe even easier
my car is at about 86k miles right now.
Old Jun 6, 2004 | 12:16 AM
Daboi630's Avatar
check the fluid. that might be the problem
Old Jun 6, 2004 | 12:27 AM
Default Re: (Daboi630)
ok i just went out to test if the clutch was truley dead.
i was cruising at 30mph and then floored it into 5th gear to see if my rpm's would climb like they would if i were in neutral...NOTHING happened.
in fact, my clutch went back feeling normal again. its ****** weird, like i'm glad it feels normal again, but i'm afraid something could still be wrong SOMETHING and i have no idea what it could be? maybe the clutch pedal springs?
any help would be great
Old Jun 6, 2004 | 03:40 AM
thehondaguru's Avatar
Default Re: (Jon Like Wh0a)
I had a fluck thing like that happen to me before. just keep an eye onit.
another thing youcan do is stop put it in 5th gear andtry to start and if it doenst stall its a bad or really worn clutch
Old Jun 6, 2004 | 10:25 AM
Default Re: (95 lude)
some people were saying that it might be the clutch springs?? or cable or something??
Old Jun 6, 2004 | 12:40 PM
VTECRaZeR's Avatar
If one of the springs breaks on ure stock clutch you might be able to hear it in ure tranny casing when it rotates. That happened to me, the damn spring broke off the clutch and I say less then 2 months later it went bad. I guess the springs really messes up the surface of ure clutch because its in the way when you shift.
So pay attention to any strange sounds. And if you do hear anything like that, start saving some cash and change ure clutch a.s.a.p.
Old Jun 6, 2004 | 01:12 PM
Default Re: (VTECRaZeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECRaZeR &raquo;</TD></TR><TR><TD CLASS="quote">If one of the springs breaks on ure stock clutch you might be able to hear it in ure tranny casing when it rotates. That happened to me, the damn spring broke off the clutch and I say less then 2 months later it went bad. I guess the springs really messes up the surface of ure clutch because its in the way when you shift.
So pay attention to any strange sounds. And if you do hear anything like that, start saving some cash and change ure clutch a.s.a.p.</TD></TR></TABLE>
what do these strange sounds sound like?
Old Jun 6, 2004 | 01:34 PM
crdcz03's Avatar
Fortune Cookie Member
you're probably low on clutch fluid. which might be caused by a leak in the master or slave cylinder.
i had the same problem with my 2nd (and current) lude for like 3 months after i bought it. i just thought it was an aftermarket clutch and stuff, but it turns out that i had a leaking master and slave cylinder.
although i loved it when it caught down low like that hehe
definitely get it fixed tho b/c if it gets too low you wont be able to put it in gear... (happened to me...) and if it does happen, pump the clutch A LOT. and carry around a bottle of dot 3 brake fluid just in case, so you can pull over and refill as needed.
Old Jun 6, 2004 | 02:06 PM
Default Re: (crdcz03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crdcz03 &raquo;</TD></TR><TR><TD CLASS="quote">
definitely get it fixed tho b/c if it gets too low you wont be able to put it in gear... (happened to me...) and if it does happen, pump the clutch A LOT. and carry around a bottle of dot 3 brake fluid just in case, so you can pull over and refill as needed.</TD></TR></TABLE>
how much do you think it'll cost to get totally fixed? i don't want to have to carry around brake fluid all the time haha...thanks
Old Jun 6, 2004 | 02:20 PM
crdcz03's Avatar
if it is actually the master and/or slave cylinder... then *looking at reciepts from teh honda dealer* i got the master cylinder for $113 and the slave for $68
but i also work there, so i get employee discount. so id have to guesstimate about $150 and $85?
and if you dont do it yourself then you can also factor in the dealerships "rape me then fix my car" labor price lmao
or if you're around central florida i can have a guy do it for you for fairly cheap and/or get you teh parts for a lil bit more than i got them.
Old Jun 6, 2004 | 02:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crdcz03 &raquo;</TD></TR><TR><TD CLASS="quote">if it is actually the master and/or slave cylinder... then *looking at reciepts from teh honda dealer* i got the master cylinder for $113 and the slave for $68
or if you're around central florida i can have a guy do it for you for fairly cheap and/or get you teh parts for a lil bit more than i got them.</TD></TR></TABLE>
haha i work at a honda dealership as well
so how do i check if it they are leaking? i'm a complete noob when it comes to engine bay stuff, so i don't even know where the master/slave is located
after you replaced the master/slave cylinders, was everything back to normal?
Old Jun 6, 2004 | 02:42 PM
crdcz03's Avatar
well i dont know how to tell if they are leaking... but i guess since you also work at a dealership then you could have your favorite mechanic check it out for you.
master cylinder resovoir is right next to the brake master cylinder and the actual cylinder is under the dash right above your clutch pedal... you'll replace all of that.
the slave is to the left of the header down by the front motor mount.
after i replaced all that my clutch pedal was normal and i hated it, but have since grown to get used to it... i liked it when it was catchy down 1 inch off the floor lmao
Old Jun 6, 2004 | 02:53 PM
haha alright, thanks for your help
Old Jun 6, 2004 | 06:59 PM
dannyd2004's Avatar
Default Re: is my clutch out?! (Jon Like Wh0a)
Same thing happened to me.
I replaced my master cylinder, that wasnt it. Then I replaced the slave cylinder.
Problem solved!
Really didnt care about spending money on the new master, now I know that both will last another 90,000 miles.
Old Jun 6, 2004 | 07:14 PM
PhazedSI's Avatar
Have you tried bleeding your clutch? Could be the problem.
Old Jun 7, 2004 | 12:34 AM
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crdcz03 &raquo;</TD></TR><TR><TD CLASS="quote">well i dont know how to tell if they are leaking... but i guess since you also work at a dealership then you could have your favorite mechanic check it out for you.
after i replaced all that my clutch pedal was normal and i hated it, but have since grown to get used to it... i liked it when it was catchy down 1 inch off the floor lmao </TD></TR></TABLE>
the clutch fluid reservoir if its low on fluid its leaking. the system is just like a brake system. air can only get in if the system has leaks, or the fluid runs out totally and air gets sucked in. bleeding a leaking system will not fix the problem. the source of the leak must be found. look under the dash and see if tehre is fluid near around your pedal.
your going to end up doing damage.
Old Jun 7, 2004 | 08:23 AM
Default Re: (IVI)
well i took my car into the honda dealership i work at this morning, so hopefully everything will work out...thanks for your help guys
legend97
Transmission & Drivetrain
Jul 6, 2017 07:45 AM
jdmstyleEJ6
12
May 9, 2010 04:13 PM
Street Racer X
Sep 21, 2008 02:35 PM
s2kkid
Apr 6, 2004 04:01 PM
hybrider
Aug 3, 2002 12:53 PM
