squeek after coilover install***
Old Jun 5, 2004 | 08:31 PM
wpgcivic's Avatar
Default squeek after coilover install***
well i have my toms motorsport coilovers on now but when i turn left i always get a high pictched squeeking noise, never had it before...any ideas?
Old Jun 5, 2004 | 09:21 PM
DXDOHCVTEC's Avatar
If it is slammed it is prolly a tire rubbing.
Old Jun 5, 2004 | 11:56 PM
null.'s Avatar
Default Re: (DXDOHCVTEC)
sleeves?
Old Jun 6, 2004 | 03:03 AM
wpgcivic's Avatar
sleeves? well yes it is slammed but why would it only rub on a left turn and not a right, also why would tires make a squeek?
Old Jun 7, 2004 | 10:20 PM
JFG Kevin's Avatar
Default Re: (wpgcivic)
do you have stock gsr top struct bar?....if so...your shocks nut might be hitting it...that's what happen to mines...swap out my oem strust bar with my bro's type r
Modified by aznstyler119 at 7:32 AM 6/8/2004
Old Jun 7, 2004 | 10:22 PM
FlexW99's Avatar
Default Re: (aznstyler119)
lowering a car with stock struts (if this is your setup) will tend to wear them out quicker and they will squeek.
Old Jun 7, 2004 | 11:34 PM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: squeek after coilover install*** (wpgcivic)
where exactly is the noise coming from? this might help you pinpoint the problem. I'm willing to bet it's coming from the right rear.
Old Jun 8, 2004 | 04:37 AM
wpgcivic's Avatar
no its coming from the front left, i am going to take a better look closer to see if there is anything loose.
Old Jun 8, 2004 | 04:41 AM
crx_88_si's Avatar
tire rub I bet. even tho only when u turn right or left. Slight alignment differences might just be enough to cause one side to rub and not the other. Does it happen only at a certain steering wheel position?
Old Jun 8, 2004 | 05:27 AM
wpgcivic's Avatar
Default Re: (crx_88_si)
yeah i am going to get a front end alignment, see if maybe this will fix it, and yes it only comes at a certain wheel position
Old Jun 8, 2004 | 07:46 AM
FlexW99's Avatar
Well.
I assumed an alignment was done already. New coilovers and no alignment?..
Could have been tires runnin on 1 area of tread.
Old Jun 8, 2004 | 10:38 AM
bluesiTYPER's Avatar
Did you use sleeve coilovers or a true coilover setup??
Apply some bearing grease to the top and bottom of where the spring rides; if it is a sleeve coilover, also to where the sleeve sits..This will solve the noise problem if its coming from the coilovers..
Old Jun 8, 2004 | 12:09 PM
ProjectCRXtacy's Avatar
Default Re: (FlexW99)
Overtorqued? Maybe? Some superman trying to tighten the bolts?
Old Jun 8, 2004 | 12:15 PM
wpgcivic's Avatar
my brother did the job, yes he is pretty big , but i will update you guys once the alignment is done, thx a lot for the suggestions
EKsedan715
Nov 30, 2010 02:06 PM
turbotime
May 6, 2007 03:21 PM
vegaspartyy
Aug 6, 2006 03:50 PM
svtec
Jan 15, 2003 10:52 PM
