Clunking/knocking noise under load...
Old Jun 5, 2004 | 07:08 PM
whatcivic's Avatar
Default Clunking/knocking noise under load...
Hi guys. I did a bunch of searches on this and got it narrowed down to detonation, bad rod bearing or tranny problem (so I don't really have it narrowed down..). Anyways I hace a b16a w/CTR pistons and valvetrain/OBD1 converison tuned with hondata. When I let out the clutch in first I get a clunking noise for the first 1-2k rpms. Now if I'm in motion and I'm in the low RPM range and I give it gas I get that same clunking/pinging type noise. It goes away once I get above 3k RPM's.
Ok - now I thought that maybe I had some bad gas so today I filled with good 91 octane. (Can't get anything higher here). Noise is still there. I dynoed the car and didn't notice anything funny like I would with detonation. Spark plugs are black/burgundy. No white spots or anything.
Now - what could be causing this? My other friend with the exact same setup says he has this noise too. He doesn't seem to worried about it - but it is driving me nuts. Anyone else with this problem? Please respond.
Old Jun 5, 2004 | 07:45 PM
hondaguyef's Avatar
Default Re: Clunking/knocking noise under load... (whatcivic)
Do you here anything at idle? I was going to suggest detonation but, you ruled that out.
Old Jun 5, 2004 | 08:55 PM
whatcivic's Avatar
Default Re: Clunking/knocking noise under load... (hondaguyef)
No - at idle there's pretty much nothing. If at idle I tap the gas i can faintly hear it for about .5 second thats it.
Old Jun 5, 2004 | 10:48 PM
Muckman's Avatar
Moderator in Chief
Check your oil lately? Could be a spun bearing. Can drop the oil pan easily to check for metal filings.
Old Jun 6, 2004 | 12:05 AM
murtnabila's Avatar
Default Re: Clunking/knocking noise under load... (Muckman)
I have a hatch doin kind of the same thing. It makes noise at low rpm's and goes away at higher rpm. Plus the higher the gear the less the noise. Anything after third, no noise. In my case it the transmission (main bearing or something). But also to add on to this, it is easily noticeable that the noise is from the tranny. To you does it sound like it coming from engine or tranny?
Old Jun 6, 2004 | 01:13 AM
whatcivic's Avatar
Default Re: Clunking/knocking noise under load... (murtnabila)
Sounds like the noise is coming from the engine. It is noticable in every gear at low RPM's. Like lets say I'm driving in 3rd at 4000 rpm's and i press on the throttle there is no noise. But if I shift to 4th or 5th (rpm's drop) and step on the throttle then the noise is there. I'm stumped...
Old Jun 6, 2004 | 04:34 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatcivic &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the noise is coming from the engine. It is noticable in every gear at low RPM's. Like lets say I'm driving in 3rd at 4000 rpm's and i press on the throttle there is no noise. But if I shift to 4th or 5th (rpm's drop) and step on the throttle then the noise is there. I'm stumped...</TD></TR></TABLE>
So basically when you put a heavy "load" on the engine? I would pull the pan and check for metal particles. You may want to do this like...... ASAP!!!!! Don't junk an engine for 1 bad bearing.
damage_626
Honda Civic (2001 - 2005)
10
May 23, 2009 08:07 AM
NHswaps13203
Transmission & Drivetrain
Jan 5, 2009 09:37 AM
looneytoonz
Nov 10, 2007 06:14 AM
whatcivic
Jun 5, 2004 09:04 PM
BnEiAkUiTcY
15
May 30, 2002 09:34 AM
