Please help diagnose this problem for me
Old Jun 5, 2004 | 07:07 PM
wblakes's Avatar
Default Please help diagnose this problem for me
i just found out today that my car gives heat no matter where the temperature dial points to. i set it to the lowest temp on the dial and it still blowing out warm air instead of cool which it suppose to. does that mean my thermostat is not working anymore?
Old Jun 6, 2004 | 04:15 AM
Chiovnidca's Avatar
Default Re: Please help diagnose this problem for me (wblakes)
Is your temp control **** broken?
Old Jun 6, 2004 | 05:12 AM
wblakes's Avatar
Default Re: Please help diagnose this problem for me (Chiovnidca)
no, because when i turn it to the coldest it blows warm air and when i turn it to the hottest it blows very hot air.
Old Jun 6, 2004 | 05:46 AM
The_Todd's Avatar
Farts in the shower
Can you feel the **** or control actually adjusting when you turn the ****?
First thing I would look at is that and the climate control center and make sure the control is hooked up. Next vacuum lines.
Are you trying to turn your a/c on and its blowing hot air or just your fan?
Old Jun 6, 2004 | 07:28 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wblakes &raquo;</TD></TR><TR><TD CLASS="quote">no, because when i turn it to the coldest it blows warm air and when i turn it to the hottest it blows very hot air.</TD></TR></TABLE>
Did you pull it off and take a close look at it?
Old Jun 6, 2004 | 08:26 AM
david90's Avatar
Do you feel any resistance when turning the ****? if not then the cable controling the heater hose valve is broken or loose. If that is not the case, check the heater inlet hose valve.
Old Jun 6, 2004 | 10:24 AM
wblakes's Avatar
Default Re: (david90)
i just got done taking it apart and look at it. everything is fine, the **** still moves the cable and i look at the engine and the cable still move that **** that's about a feet below the air intake.
Old Jun 6, 2004 | 11:18 AM
Chiovnidca's Avatar
Default Re: (wblakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wblakes &raquo;</TD></TR><TR><TD CLASS="quote">i just got done taking it apart and look at it. everything is fine, the **** still moves the cable and i look at the engine and the cable still move that **** that's about a feet below the air intake.</TD></TR></TABLE>
Is it moving the heater valve through it's full range?
honda genome
Dec 28, 2006 06:37 AM
simplypinoyy
Feb 26, 2006 09:50 PM
crxtreme89h
Dec 12, 2005 03:17 PM
W.O.P.
Apr 14, 2004 04:44 PM
crafty
Nov 4, 2003 06:09 PM
