Coolant under driverside floormat!!!
Old Jun 5, 2004 | 04:51 PM
zman's Avatar
Default Coolant under driverside floormat!!!
i have a 95 civic w/b16 swapped in about a week ago. There is a HUGE puddle of coolant under the driverside floormat. Also coolant is leaking from under the engine bay, by where the heater hose from the thermostat goes into the firewall (to the heater core i think). There is no coolant anywhere else in the car other than the under the driverside floormat. I just replaced the thermoswitch today but there is not coolant leaking from there.
Old Jun 5, 2004 | 04:59 PM
photec2's Avatar
Default Re: Coolant under driverside floormat!!! (zman)
may have cracked your heater core. sounds like your close to the problem good luck
Old Jun 5, 2004 | 05:09 PM
mikehawkBUiLT's Avatar
wow, goodluck with that
Old Jun 5, 2004 | 05:11 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (EJcoupe)
most likely coming from the heater core.
Old Jun 5, 2004 | 05:20 PM
built562's Avatar
Default Re: (AzntaggeR)
its the heater core for sure, just get the 2 hoses that go into the heater core and connect them together using a barbed hose coupler and you will be fine until you have time to replace the core.
Old Jun 5, 2004 | 05:25 PM
zman's Avatar
Default Re: (akumaracer)
So what causes heater cores to break? Is it possible that something was done during the swap. The car has overheated 3 times since the swap and the coolant was disappearing...i guess i now know where it was going.
Old Jun 5, 2004 | 07:37 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (zman)
check the two hoses going into the heater core from the engine bay. sometimes during a swap those don't get reclamp as good. i had the same problem except i was leaking coolant onto the ground instead of the floorboards.
Old Jun 5, 2004 | 08:16 PM
dunkd's Avatar
yup heater core... take out dash, take off the two hoses in the engine bay, unnblot heater box, and then slip out the heater core and insert new one
Old Jun 5, 2004 | 08:47 PM
honda9369's Avatar
it could be your heater control valve
i believe the heater core is on your pass. side
Old Jun 5, 2004 | 08:58 PM
dunkd's Avatar
Default Re: (honda9369)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda9369 &raquo;</TD></TR><TR><TD CLASS="quote">it could be your heater control valve
i believe the heater core is on your pass. side</TD></TR></TABLE>
its right in the middle... i changed mine this past winter, mine as well leaked on the driverside floor... nice puddle.
LGxGirL
Nov 26, 2012 10:58 AM
Ayashifx55
Dec 23, 2010 10:01 PM
Rival23
Oct 25, 2003 09:34 AM
