PIVOTRACING USA/CARBON FIBER PLATES/SHEETS
SUPER EARTH ENGINE GROUND SYSTEM
• Increases Torque at Low and Middle Speeds
• Improves Engine Response
• Increases Headlight Brightness
• Improves Bass Sound
PIVSE-5M This kit is designed for custom installation of the Pivot Super Earth Grounding System. Five meter long cables can be cut to match any car or any system. Connectors are included, but are not crimped to the cables. This allows the cables to be installed at any length.
PIVSE-TT This kit is designed with the novice in mind. The cables have been precut into lengths of 100,80,60,50, and 40 cm. The contacts have been crimped and are connection ready.
PIVSE-5M This kit is designed specifically to match your cars specifications. All the cables are cut and the contacts are in place for a super easy installation.
With all of the engineering going into modern cars, a strange thing has been overlooked by manufacurers. A good grounding system dedicated specifically to the ignition. It may not seem like much, but by installing these wires you will see an increase in power, brigher lights, and improved sound quality. You may be skeptical, but we tested the system on several cars, some with already great ignition systems (Lexus). We saw increases as much as 7 foot lbs. and 5 horsepower throughout the rev renge. Not bad for a few ground wires.
SUPERTEMP CONTROLLER
Fan Controller with Water or Oil Temperature Gauge
• Illuminated Switches and LED Readout
• Hold Peak Temperature Function
• Auto or Manual Display
• No Hose Connection Required for
Water Temperature Sensor
http://www.pivotusa.com/<---click here we can get antying form PIVOT
NEW! Carbon Fiber Sheets are available in several thicknesses and sheet sizes. The 0.2mm comes single side finished and with optional adhesive backing. All others are double side finished. Currently we're offering all of our carbon fiber in the latest 2x2 twill pattern which creates a subtle horizontal striped pattern.
• 2x2 Twill Pattern
• Double Sided
• Universal Application
10"x12"
10"x24"
39"x47"
comes in:
0.2mm
0.5mm
1.0mm
1.5mm
3.0mm Sheets
price will be posted shortly. We are trying to get the best pricing for H-T members. If anyone is intersted please post a reply.
Modified by camp1320.com at 5:51 PM 6/5/2004
• 2x2 Twill Pattern
• Double Sided
10"x12"
10"x24"
39"x47"
comes in:
0.2mm
0.5mm
1.0mm
1.5mm
3.0mm Sheets
Might be interested in your carbon plates. Would like to see some pricing though
And quick question: what do you need to cut the plates? Dremel and diamond cutting wheel?
Modified by nw.dave at 9:15 PM 6/8/2004
Pretty Cool, Send me More Pics at itsdusk2dawn@netscape.net
How much will the pivot temp controller be? It includes the sensors correct? Can you have both the water and oil temp sensors connected? Lastly, it looks like the display can only show 2 digits, so what does it show when temps rise above 99 deg?
HAY71.02.13 .2mm SINGLE CARBON W ADHESIVE TWILL 9.7"x12" $16.80
HAY71.02.15 .2mm SINGLE CARBON W ADHESIVE TWILL 9.7"x24" $33.60
HAY71.02.16 .2mm SINGLE CARBON W ADHESIVE TWILL 12"x39" $60.00
HAY71.02.17 .2mm SINGLE CARBON W ADHESIVE TWILL 39"x47" $216.00
HAY71.02.53 0.2mm SINGLE CARBON W/O ADHESIVE TWILL 9.7"x12"$16.80
HAY71.02.55 0.2mm SINGLE CARBON W/O ADHESIVE TWILL 9.7"x24'$33.60
HAY71.02.56 0.2mm SINGLE CARBON W/O ADHESIVE TWILL 12"X3 $60.00
HAY71.02.57 0.2mm SINGLE CARBON W/O ADHESIVE TWILL 39"x4 $216.00
HAY71.05.13 0.5mm DBL CARBON TWILL 9.7"x12" $26.40
HAY71.05.15 0.5mm DBL CARBON TWILL 9.7"x24" $51.60
HAY71.05.16 0.5mm DBL CARBON TWILL 12"x39" $102.00
HAY71.05.17 0.5mm DBL CARBON TWILL 39"x47" $408.00
HAY71.10.13 1.0mm DBL CARBON TWILL 9.7"x12" $28.50
HAY71.10.15 1.0mm DBL CARBON TWILL 9.7"x24" $56.40
HAY71.10.16 1.0mm DBL CARBON TWILL 12"x39" $112.50
HAY71.10.17 1.0mm DBL CARBON TWILL 39"x47" $450.00
HAY71.15.23 1.5mm DBL CARBON TWILL 9.79"X12" $32.40
HAY71.15.25 1.5mm DBL CARBON TWILL 9.79"X24" $64.80
HAY71.15.27 1.5mm DBL CARBON TWILL 39"X47" $480.00
HAY71.30.23 3mm DBL CARBON TWILL 9.79"X12" $38.40
HAY71.30.25 3mm DBL CARBON TWILL 9.79"X24" $76.80
HAY71.30.27 3mm DBL CARBON TWILL 39"X47" $552.00
HAY72.06.02 CARBON TUBE 24"(L) x 1/42"(T) x 1/8"(I.D) $18.00
HAY72.06.03 CARBON TUBE 24"(L) x 1/42"(T) x 3/32"(I.D. $15.60
HAY72.06.04 CARBON TUBE 24"(L) x 1/42"(T) x 1/4"(I.D.) $21.60
HAY72.06.05 CARBON TUBE 24"(L) x 1/42"(T) x 3/8"(I.D.) $32.40
HAY72.06.06 CARBON TUBE 24"(L) x 1/42"(T) x 1/2"(I.D.) $36.00
HAY72.06.07 CARBON TUBE 24"(L) x 1/42"(T) x 5/8"(I.D.) $42.00
HAY72.06.08 CARBON TUBE 24"(L) x 1/42"(T) x 3/4"(I.D.) $46.80
HAY72.06.09 CARBON TUBE 24"(L) x 1/42"(T) x 7/8"(I.D.) $54.00
HAY72.06.10 CARBON TUBE 24"(L) x 1/42"(T) x 1"(I.D.) $60.00
HAY72.06.11 CARBON TUBE 24"(L) x 1/42"(T) x 2"(I.D.) $96.00
HAY72.06.12 CARBON TUBE 24"(L) x 1/42"(T) x 2.5"(I.D.) $114.00
HAY72.06.13 CARBON TUBE 24"(L) x 1/42"(T) x 3.0"(I.D.) $126.00
These are the pricing including shipping. I hope these are the right prices i got. We will not only match but BEAT any pricing from SPW/HAYAME/PIVOT racing usa.
PIVOT RACING USA INCLUDES SHIPPING
PRICES ARE SUBJECT TO CHANGE WITHOUT NOTICE. .
Part No Description Retail
PIVASL-MB PIVOT AUTO SHIFT LAMP BLUE $106.80
PIVASL-MR PIVOT AUTO SHIFT LAMP RED $106.80
PIVASL-MW PIVOT AUTO SHIFT LAMP WHITE $106.80
PIVACS-R PIVOT AIR FLOW CONTROLLER $307.99
PIVADL PIVOT MULTIPLE DATA LOGGER(INJECOTR, AIR FLOW RATIO) $651.10
PIVAFA PIVOT ANALOG AIR FLOW METER W RACE SPEC O2 SENSOR $535.34
PIVAH-1 PIVOT PILLAR-MOUNT METER HOLDER 60MM $31.01
PIVBH-1 PIVOT BAND HOLDER 60MM $18.60
PIVBIT-X PIVOT BUILT-IN TURBO TIMER $121.94
PIVBIT-X1 PIVOT BUILT-IN TURBO TIMER IMPREZA GC8/CF8 $134.35
PIVBIT-X2 PIVOT BUILT-IN TURBO TIMER WRX GDA/B GGA/B $134.35
PIVBIT-X3 PIVOT BUILT-IN TURBO TIMER LEGACY BE5 BH5 $134.35
PIVBM-B PIVOT BOOST METER BLUE W/ HOLDER(SAME AS PIVRBM-BL) $183.96
PIVBM-R PIVOT BOOST METER RED W/ HOLDER (SAME AS PIVBM-IS) $183.96
PIVBM-Y PIVOT BOOST METER YEL W/ HOLDER (SAME AS PIVRBM-IY) $183.96
PIVCDT PIVOT COUNT DOWN TIMER $98.18
PIVDTML PIVOT DIGITAL TACHO LAMP $183.96
PIVFCG PIVOT FAN CONTROLLER & WATER TEMP GAUGE DIGITAL READOUT $170.52
PIVFLAT-BK PIVOT TURBO TIMER FULL AUTOMATIC BLACK $102.31
PIVISK-R PIVOT PUSH BUTTON STARTER RED LIGHT $106.80
PIVMAS PIVOT MOVING ARM SHIFT $98.18 $117.82
PIVOL-H PIVOT "OUTLOW" SHORT THROW SHIFT **** HONDA $98.40
PIVOL-N PIVOT "OUTLOW" SHORT THROW SHIFT **** NISSAN/MITSUBISHI
$98.40
PIVOL-T PIVOT "OUTLOW" SHORT THROW SHIFT **** TOYOTA/SUBARU M12 X 1.25 $98.40
PIVRBM PIVOT 7-COLOR RACING BOOST METER $183.96
PIVRBM60 PIVOT BOOST METER 60mm 7-COLOR $183.96
PIVRBM-XB PIVOT BOOST METER "7-COLOR MODE" BLK FACE $183.96
PIVRBM-XW PIVOT BOOST METER WHITE 7-COLOR $183.96
PIVRBM-Z PIVOT BOOST METER $183.96
PIVRC1 PIVOT RADIATOR CAP (SUBARU,NISSAN,TOYOTA,MITU.,MAZDA,HONDA) $35.14
PIVRC2 PIVOT RADIATOR CAP (SUZUKI,DAIHATSU,NISSAN,TOYOTA,MITU.,HONDA) $35.14
PIVRHU-M PIVOT HEADLIGHT CONTROLLER $127.20
PIVRS-1 PIVOT RACING STARTER SWITCH $72.34
PIVRS-1B PIVOT RACING STARTER SWITCH BLUE $72.34
PIVRS-1Y PIVOT RACING STARTER SWITCH YEL $72.34
PIVRSL PIVOT RACING SHIFT LAMP $155.02
PIVRVM60 PIVOT VACUUM METER 60mm $183.96
PIVSBT PIVOT SUPER BABY TIMER(WORLD'S SMALLEST TURBO TIMER!) $121.94
PIVSBT-BL PIVOT SUPER BABY TURBO TIMER CL/BL $121.94
PIVSBT-R PIVOT SUPER BABY TURBO TIMER RED $121.94
PIVSE-3ML PIVOT SUPER EARTH UNIVERSAL 3-METER COMPLETE KIT BLUE $73.00 $87.60
PIVSE-5M PIVOT SUPER EARTH UNIVERSAL KIT 5 METER KIT $73.00 $87.60
PIVSE-5ML PIVOT SUPER EARTH UNIVERSAL 5-METER COMPLETE KIT BLUE $87.60
PIVSE-P4 PIVOT SUPER EARTH WIRE KIT 4 CYL $73.00 $87.60
PIVSE-P6 PIVOT SUPER EARTH WIRE KIT 6 CYL (INLINE) $102.00
PIVSE-TT PIVOT SUPER EARTH UNIVERSAL COMPLETE KIT $102.00
PIVSE-TTL PIVOT SUPER EARTH UNIVERSAL COMPLETE KIT BLUE $102.00
PIVSG-BP PIVOT BOOST PRESS/SENSOR STEPPING DRIVE QUICK & ACCURATE RESPONS $225.31
PIVSG-BPG PIVOT GEKKO BOST PRESS W/SENSOR STAPPING-D $287.30
PIVSG-IT PIVOT INTAKE AIR TEMP/SENSOR STEPPING DRIVE QUICK & ACCURATE RESPONSE $225.31
PIVSG-OP PIVOT OIL PRESSURE W/ SENSOR STEPPING MOTOR DRIVEN $411.34
PIVSG-OPG PIVOT GEKKO OIL PRESS W/SENSOR STAPPING-D $423.74
PIVSG-OT PIVOT OIL TEMP W/SENSOR STEPPING DRIVE QUICK RESPONSE $225.31
PIVSG-OTG PIVOT GEKKO OIL TEMP W/SENSOR STEPPING-D $225.31
PIVSG-SM1 PIVOT STEPPING DRIVE SPEED METER 320km/H $217.03
PIVSGT-F0 PIVOT TACH(STEPPING MOTOR) W SHIFT LAMP, BUILT-IN DEMO MODE!! $257.35
PIVSGT-F0G PIVOT GEKKO TACHO METER W/S-LAMP STAPPING-D $307.99
PIVSGT-F1 PIVOT TACH(STEPPING MOTOR) W SEQUENTIAL SHIFT LAMP, BUILT-IN DEMO MODE $245.98
PIVSGT-F1G PIVOT GEKKO TACHO METER W/S-LAMP STEPPING-D $287.30
PIVSG-VP PIVOT VACUUM PRESS/SENSOR STEPPING DRIVE QUICK & ACCURATE RESPONSE $257.35
PIVSG-VPG PIVOT GEKKO VACCUM PRESS W/SENSOR STAPPING-D $307.99
PIVSG-WTS PIVOT WATER TEMP STEPPING DRIVE QUICK RESPONSE $183.96
PIVSG-WTSG PIVOT GEKKO WATER TEMP STEPPING-D $217.03
PIVSG-WTX PIVOT WATER TEMP W/SENSOR STEPPING DRIVE QUICK RESPONSE $217.03
PIVSG-WTXG PIVOT GEKKO WATER TEMP W/SENSOR STEPPING-D $266.64
PIVSML-X PIVOT SPEED METER $132.00
PIVSML-Z PIVOT SPEED METER (W CORNERING SPEED MEMORY) 1/4 MILE SPEED $216.00
PIVSSK-L PIVOT PUSH BUTTON STARTER(PROGRAMMABLE) BLUE $168.00
PIVSSK-R PIVOT PUSH BUTTON STARTER(PROGRAMMABLE) RED $168.00
PIVSSL-M PIVOT SHIFT-UP LAMP $110.59
PIVSSL-P PIVOT SUPER SHIFTING LAMP $155.02
PIVSSL-X PIVOT SUPER SHIFT LAMP $155.02
PIVSTC PIVOT SUPER TEMP. CONTROLLER $257.35
PIVVS-1 PIVOT RAIZIN VOLT STABILIZER $126.00
PIVVS-E PIVOT RAIZIN VOLT STABILIZER W/EARTH CABLE $180.00
PIVVTC-R PIVOT V-TEC CONTROLLER/AIR FLOW CONTROLLER $279.05
PIVWSC PIVOT WATER SPRAY CONTROLLER $204.62
PIVWSN-1 PIVOT WATER SPRAY NOZZLE KIT $50.64
PIVWTG PIVOT WATER TEMPERATURE GAUGE, DIGITAL READOUT $134.35
$98.40
this comes with all the sensors right?
and is this the one pictured above? does that one come with all sensors?
yes they come wit hthe neccesery sensors to make the parts work.
We have most of them in stock now.
ready to ship
ready to ship
pricing is posted above. scroll up to my post on the whole pricing list. We have everything in stock.
install is very easy comes with instructions
SORRY GUYS, MOST OF THE TIMES WE CAN GET ORDERS OUT THE SAME DAY, BUT OTHER TIMES IT WILL BE A FEW DAYS, WE HAVE BEEN SUPER SWAMPED WITH RACE SEASON AND ALL WE SUPPORT RACING AND NOT ONLY HERE TO TRY TO MAKE $$$ WE GO TO ALL THE LOCAL EVENTS,HELPING OUT FELLOW RACERS AND ENTHUSIST, SORRY WE CANT NOT BE ONLINE 24/7 BUT FEEL FREE TO CALL US AT OUR SHOP OR FAX ORDER OR EMAIL WE WILL TRY TO GET THEM OUT ASAP..!!
