Catalytic Converter or Straight Pipe
My integra is in need of either a new cat, or a straight pipe. I don't really want the straight pipe b/c of the noise, but I'm also selling the Integra by the end of the summer so it doesn't really matter to me. I have a Jackson Racing cat on it now, but all the welds are cracked because it's a cheap p.o.s. Anyone know any good brands for cats and straight pipes?
it depends on what you have done to your car. if its mostly stock get another cat. a straight pipe wont relaly help on your car unless you have alot of work or a turbo.
itll only smell. destroy the enviornment. be dealy for you to inhale. produce sut all over ur bumper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI »</TD></TR><TR><TD CLASS="quote">it depends on what you have done to your car. if its mostly stock get another cat. a straight pipe wont relaly help on your car unless you have alot of work or a turbo.
But more HP HAHA so its either the person u racin die or you be dead and its funny drivin slow but its also fun drivin fast
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iiiskipiii »</TD></TR><TR><TD CLASS="quote">
But more HP HA HA so its either the person u racin die or you be dead and its funny drivin slow but its also fun drivin fast</TD></TR></TABLE>
You'd be hard pressed to get more than a 3-4 Hp Advantage over the Car-sounds Cat if you went with a straight Pipe. Hardly a worth while advantage.
You'd be surprised at how much better your car will run with a High Flow Cat plus you'll still be able to pass Emissions test.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI »</TD></TR><TR><TD CLASS="quote">its actually worse for ur motor to lower the backpressure too much.
a striaght pipe when not needed makes u lose some torque.
Exactly.
go with carsound
Exactly.
go with carsound
Get a kitty, pass emissions! If you dont require it where you live then you should get what you think is better. That's my opinion.
if your going to sell it, hmmmmm i'd get the cheapest working stock cat.... hit up the junkyard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excel88 »</TD></TR><TR><TD CLASS="quote">The Carsound one is made by magnaflow right?</TD></TR></TABLE>
Yes, and it rocks. Definately passes emissions too and seems to hold up well..
to carsound
to carsound
I know I'm selling the car, but I just want to fix everything that's wrong with it before i sell it. The cat makes this awful rattling noise b/c the welds are broken. Anyone jumping in for test drive will say "**** this pos!"
just get a cheep cat if your gonna sell it. your not gonnacare about performance. if your gonna keep your car get a good cat. i dont think anyones gonna wanna buy a car with no cat either...
Instead of the carsound, get a resonated t-pipe made, it should be cheaper and add minimal noise to your exhaust
*that is if you havent already set your mind on a cat!
