ACT Flywheel help??
i need to know the correct way to install a prolite flywheel, because on the oem flywheel there is a dot lines up wit each other and on the act flywheel there isn't, some body help thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urgonnalearn2 »</TD></TR><TR><TD CLASS="quote">because on the oem flywheel there is a dot lines up wit each other and on the act flywheel there isn't,</TD></TR></TABLE>
The dot is on the oem fly wheel so incase you take the pressure plate off, when you go to install it back it goes in the same place. With the new fly wheel just install and it torque the bolts down to spec and your good to go
Guest
Posts: n/a
torque to spec.
i noticed that when i installed my act stage 2 clutch and p.p. that the old flywheel and clutch assy. had 6 bolts/holes and the new set up has 8. i only used six and so far it's runnin' fine.
fled
Jul 5, 2006 12:06 PM
remaxxxk
Mar 1, 2006 09:11 PM
