Annoying squeaks from rear of car (hatch)
Old Jun 5, 2004 | 11:15 AM
wreckedmyteg's Avatar
Default Annoying squeaks from rear of car (hatch)
Does anybody know how to get rid of the annoying *** squeaks that come from the back of the car?!
Old Jun 5, 2004 | 11:38 AM
debogsr's Avatar
Default Re: Annoying squeaks from rear of car (wreckedmyteg)
I hate that noise. Turn up your music!
Old Jun 5, 2004 | 11:40 AM
Ti3d in's Avatar
Default Re: Annoying squeaks from rear of car (debogsr)
Just open up the hatch and literally pound every body panel, trimming, etc you see until you hear squeaks. It's usually from metal to metal contact.
Old Jun 5, 2004 | 04:40 PM
DIY's Avatar
DIY
Default Re: Annoying squeaks from rear of car (Ti3d in)
i added a c pillar bar.. voila .. squeeking gone *shrugs* dunno really why.. but...
Old Jun 5, 2004 | 05:21 PM
GSRoadRage's Avatar
Default Re: Annoying squeaks from rear of car (DIY)
Damn those pillar bars really do help. I just oiled and greased my trunk latch and the ball joints where the trunk struts/shocks attach and my squeeks went away. But yeah it is the panneling too sometimes.
Old Jun 5, 2004 | 05:52 PM
kablamo's Avatar
if you find that the squeak comes from plastic on plastic or plastic on metal contact, go to a parts store and buy some foam tape (usually used in pickup trucks with bed liners, to protect the metal from becoming scratched and rusting).
it only needs to be 1/2 or even 1/4 inch of foam on the tape, and you can stick that wherever there is contact, should stop most of it.
for metal on metal contact, good thick lubricants in sprays (NOT WD-40) are good, as well as bearing or chassis lube, which is a thick grease. anything that isn't likely to run off or dry up.
like others said, it's not ONE thing...
dont' forget to check the plastic trim pieces that surround the big window in the hatch... i remember i had a NASTY noise coming from there one time, because 2 pieces weren't put back together properly.
hope this helps!
Old Jun 5, 2004 | 07:13 PM
Infinity_Racer's Avatar
i had the same problem...it was my latch in the rear...i just wrapped it up with electrical tape and the noise went away.
Old Jun 9, 2004 | 04:47 PM
Default Re: Annoying squeaks from rear of car (Infinity_Racer)
I think it's coming from the strut towers. Gonna lube up the poly bushings I used in the top plates.
Old Jun 10, 2004 | 01:05 PM
Cliffjumper2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kablamo &raquo;</TD></TR><TR><TD CLASS="quote">
hope this helps!</TD></TR></TABLE>
Old Jun 10, 2004 | 01:14 PM
Seedc2's Avatar
Default Re: Annoying squeaks from rear of car (DCcliffjumper2)
gonna check stuff out now.. cuz somethings been rattling there for quite a while now.
Old Jun 10, 2004 | 04:52 PM
Default Re: Annoying squeaks from rear of car (kendogg)
yeah I had an annoying squeak coming from my hatch area for a week, and I assumed I didn't clip in my cargo cover correctly....but upon closer inspection.....I had forgot to pop in a clip last time I took off my side panel, so I made sure all my fragile little clips were inline with their holes, and pushed them back in........squeak gone.
But don't go gorilla on your plastic panels and just start pounding them into place cause you will break the clips and then you will have to live with that squeaking........that is of course till you find another way to stop it
magic94gsr
Jun 11, 2008 10:07 PM
Sanj
Apr 2, 2007 06:17 PM
GreenBean
21
Feb 6, 2004 08:35 AM
Ralph Wiggum
Jan 19, 2003 09:22 AM
CWITR
Apr 17, 2002 04:29 PM
