DOES THIS ESTIMATE SOUND ABOUT RIGHT?
Old Jun 5, 2004 | 10:30 AM
southphillyman
Guest
Posts: n/a
Default DOES THIS ESTIMATE SOUND ABOUT RIGHT?
400 for a valve cover gasket , a tune up, and engine diagnostic?
so it wasnt my transmission and my car is not for sell anymore.
but is that a lil steep for valve cover gasket?
o yea to keep this accord related. its on my 91 accord ex.
the car was shaking when i shifted gears so i thought it was my transmission. took it in and they say it needs a tune up because the drivetrain is putting too much pressure on the weak engine. iono, i swore it was the trans. anyway they saying the engine is weak because the valve gasket flooded the plugs wit oil.
Modified by southphillyman at 8:00 PM 6/5/2004
Old Jun 5, 2004 | 10:55 AM
The_Todd's Avatar
Farts in the shower
Default Re: DOES THIS ESTIMATE SOUND ABOUT RIGHT? (southphillyman)
You could DIYeverything (unless can't do it yourself) for <200 dollars.
If you add in labor (60-80 bucks an hour) it would come in around 300-400.
Old Jun 5, 2004 | 10:58 AM
southphillyman
Guest
Posts: n/a
Default Re: DOES THIS ESTIMATE SOUND ABOUT RIGHT? (VRDrvr)
so that price sounds about right?
i'm asking because these same guys tried to charge me $800 for a new distributor, then i brought one offline for $150 and did the job myself. so i think they might be shifty, but its a POPULAR mechanic spot wit tons of customers, i dont see why they would be ballooning prices and ****
Old Jun 5, 2004 | 11:10 AM
The_Todd's Avatar
Farts in the shower
IMO use your chiltons manual it (I believe) tells you everything needed for a tune up. Look at that and see if anything is out of your league as far as the valve cover gasket, if you can do the dizzy, you can do the gasket. I would tell them for just the tune up and diagnostic .
Old Jun 5, 2004 | 11:17 AM
southphillyman
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">IMO use your chiltons manual it (I believe) tells you everything needed for a tune up. Look at that and see if anything is out of your league as far as the valve cover gasket, if you can do the dizzy, you can do the gasket. I would tell them for just the tune up and diagnostic .</TD></TR></TABLE>
wouldnt i have to do the gasket before the tune up tho? if **** is leaking out, ya know. doing the tune up might be point less
Old Jun 5, 2004 | 11:57 AM
The_Todd's Avatar
Farts in the shower
Well like I said it depends on what is wrong...usually a tune up includes:
seals, valves, compression, timing, wear of parts (belts, components etc).
Old Jun 5, 2004 | 05:29 PM
Xumarius's Avatar
https://honda-tech.com/zerothread?id=886506
Old Jun 5, 2004 | 06:35 PM
southphillyman
Guest
Posts: n/a
Default Re: DOES THIS ESTIMATE SOUND ABOUT RIGHT? (Xumarius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xumarius &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=886506</TD></TR></TABLE>
ur an idiot
stop stalking me
Old Jun 5, 2004 | 07:18 PM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by southphillyman &raquo;</TD></TR><TR><TD CLASS="quote">
ur an idiot
stop stalking me</TD></TR></TABLE>
bwhahaa.....i think its funny that u wanna sell ur car w/ a broken slush box, but then when u actually get it diagnosted, u decide to keep ur car.....
price sounds legit, but its still high IMO (these $80+/hr labor rates are a joke IMO)
so did u sell ur bad *** baller rimz yet?
Old Jun 5, 2004 | 07:40 PM
southphillyman
Guest
Posts: n/a
Default Re: DOES THIS ESTIMATE SOUND ABOUT RIGHT? (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">bwhahaa.....i think its funny that u wanna sell ur car w/ a broken slush box, but then when u actually get it diagnosted, u decide to keep ur car.....
so did u sell ur bad *** baller rimz yet?</TD></TR></TABLE>
naw didnt sell the rims , i had them on ebay. and it was getting close to the date so i increased the starting bid to 1700 so no one would bid
and how is it funny that i wanna keep my car now,lol. i found out it wasnt the trans, so i wanna keep it cause the car runs 100% and is clean. i be a fool to give it up for $1000 man. maybe $2000 +
Old Jun 5, 2004 | 07:48 PM
fw190bvi's Avatar
and how is it funny that i wanna keep my car now,lol. i found out it wasnt the trans, so i wanna keep it cause the car runs 100% and is clean. i be a fool to give it up for $1000 man. maybe $2000 +</TD></TR></TABLE>
its funny, cause u didnt really find out what the problem was, and u just wanted to sell it......then u realized how BAD of an idea that was, got it checked out, and turned out it was just a bad headgasket....
Old Jun 5, 2004 | 08:06 PM
Maxx PARANOiA's Avatar
For the record, I've got a 93 accord lx with the f22a1 and about 223k miles on it....as far as the valve cover gasket is concerned, you can save yourself tons of $$$...I replaced my valve cover gasket for &lt;$50 in parts and promtly moved on with life. There are only 4 bolts/nuts/whatever-they're-called that hold the valve cover on, and it's almost self-explanitory just by looking at it. The one big gasket around the edge of the valve cover, and the rings to go around the spark plug chamber holes (I don't know what they're really called). Then once you've replaced that, you can replace the plugs, wires, distributor cap/rotor, etc for your tune up as necessary...
And FYI, when you replace the valve cover bolts, they are supposed to be torqued to 7 ft-lbs (84 in-lbs)...
rovafa2002
Jul 2, 2013 07:50 AM
f22a1 ftw
Mar 25, 2010 08:42 PM
Cristo88
Jan 10, 2009 10:37 AM
jackiebenware
Oct 28, 2005 05:31 PM
eapoe74
Jun 4, 2005 11:43 AM
