Thanks to all that helped! Tach cluster is perfect!
Old Jun 4, 2004 | 08:36 PM
89DXDann's Avatar
Default Thanks to all that helped! Tach cluster is perfect!
Well I put in the cluster and it worked perfectly, I was even able to tuen back the odometer to read what the original correct mileage is. just a couple of questions though....
1) at nighttime, is the fuel/temp gauges dimmer than the tach and speedo?
2) anyone want a used cluster that is NOT a tach? 109,000 miles. Thanks again!
Old Jun 4, 2004 | 08:50 PM
flip b18b's Avatar
Default Re: Thanks to all that helped! Tach cluster is perfect! (89DXDann)
it sounds like you might need a new light bubl in your cluster
Old Jun 4, 2004 | 09:47 PM
CRXRageD's Avatar
agree on the dim bulb. the answer to number two is, would you want to keep a tach-less cluster? probably not.
Old Jun 4, 2004 | 11:38 PM
sit220's Avatar
take a bulb from the old cluster and put it in ur new one
Supa Troopa
62
Jul 19, 2023 10:07 AM
CERTIFIEND
Jul 28, 2015 04:49 PM
V.MoMO
Sep 12, 2010 08:44 AM
anguish
Apr 4, 2004 11:37 AM
E-lude78
Jun 5, 2003 01:20 PM
