Help 92 Accord wont start. Electrical, sensor problem?
I ran off the road and got stuck in some mud. The car was running and I shut it off It set in some water for two hours. The water was to the bottom of the car. It now wont start. I have fuel and spark but I hear like a vacuume his but dont see a line messed up. The transmission says d4 and wherever else the selector is at. The computer doesnt flash any codes the check engine light just stays on when you use a jumper wire to make them show. The car started today once and the pvc valve was snapped where it got hit when working on it, and the car was running rough when he capped it off and died and wont start again. I think the injectors are not firing but I dont know what to check. Any Ideas?
thanks
Christopher
thanks
Christopher
If the battery was unhooked since the last time you got your CEL than the codes got cleared and you have to get it to run long enough to get your CEL to come on again and then check codes.
yeah water was in the passenger side. It will start now but wont run real smooth. There are some relays that act nuts on the driver side also. Any idea on the transmission D4 staying lit up?
DETROITREX
Feb 10, 2020 07:42 PM
paulhsu
Nov 7, 2007 02:39 PM
