TWM ITB TPS QUESTIONs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal »</TD></TR><TR><TD CLASS="quote">yep, you'll need a standalone.</TD></TR></TABLE>
Where did you get this info from?
You can use the TWM tps with any ecu as long as you wire it correctly. Use the connector from a SAAB wiring harness, they use the same TPS sensor. then all you have to do is wire it up. if you like i can go through my binder and find the wireing pin outs and post it up for you, or you can come by the shop and get it....you are near me.
blu3g
12
Jul 26, 2006 11:17 AM
