ITR Parts / B18a/B16 Shortblocks / Cable B-series Tranny
I'm selling a bunch of ****, Some stuff I will ship, some I wont, Pics are linked under each item.
B16 Block w/ Crank Main caps, oil pan, tension, water pump etc. (as shown) $50 (local only)
- Pic1
B16 PR3 Rods (with factory bearings) $40 shipped
- Pic1
USDM 98 B18c5 ITR Block. Includes crankshaft, mains/girdle/windage tray/tensionar/waterpump/oil pan. This block is great for a build up. SOLD
- Pic1
- Pic2
- Pic3
92+ Big Shaft Integra Clutch, Lightened flywheel (13lbs) ACT Extreme PP, and a pretty worn GSR clutch Disc. These items have heavy abuse but worked just fine before they were taken out. $75 shipped
- Pic1
USDM 98 ITR Vtec Cylinder Head. Good core, needs new valves. Includes All springs/Retainers/keepers/Cam Caps/spray bars. Basically this head needs a set of valves, and a resurface job, along with a set of cams and your good to go. Also is missing 1 pin for the rocker assy. SOLD, waiting for payment
- Pic1
- Pic2
- Pic3
B18a Shortblock. New main bearings, B18b Rods on PR3 B16 Pistons. had 220psi across the board on comp test. Perfect for LS/vtec, includes tunertoyz fitting, Type R oil pump and oil pan. SOLD
- Pic1
- Pic2
EF 4g Civic/CRX Mounts for B-series Swap. 3 mounts total, the rear mount has been rewelded. SOLD
- Pic1
B16a OBD0 Vtec Ported/Polished Cylinder head. This head is ready for a ls/vtec conversion, Alignment dowls have been enlarged and already has the block off plug installed. (can be reversed) Includes everything shown (no cams) Has GSR Duel Inner valve springs on Intake/Exhaust. Has good Port work for FI. $350 + Shipping
- Pic1
- Pic2
- Pic3
98 ITR Clutch/Flywheel/Pressure Plate. Has 19k miles and pretty heavy abuse on clutch but still holds. Factory ITR flywheels are the lightest of the bunch. SOLD shipped
- Pic1
98 ITR B18c/B16a OBD2 Distributor $75 shipped
- Pic1
98 ITR USDM Intake Manifold w/ Fuel rail/IACV/IAT/Injectors/Fuel Pressure regulator SOLD
- Pic1
98 ITR USDM Piston/Rod Combo (no rings). Skirts have minimal wear. Comes with factory Rod bears too. 1 piston does have a slight nick on top but nothing I'd worry about. $175 Shipped
- Pic1
- Pic2
98 ITR USDM Throttle Body 62mm. Includes TPS & Map Sensor Sold
- Pic1
- Pic2
B-Series Shift linkage for 4g Civic/Crx's. This is modified crx linkage that works ok. I used it for almost 2 years, its a hacked but it works. Also includes ricey Short Shifter! $40 shipped
- Pic1
Misc Valve Covers. 1 B18 valve cover painted blue with lots of scratches ($40 shipped) / D16a6 Valve cover (black) ($20 shipped) & D16y8 Valve cover ($25 shipped)
- Pic1
93 Integra YS1 5 Speed Transmission (cable) Includes AZRace Twin Trac LSD. Grinds in 2nd & 3rd gear and 5th gear bearing makes some noise. Other than that its fine. I've beat the **** out of this tranny, only reason I'm taking it out I got something better
Also keep in mind this tranny is one of the only Cable B-series tranmission you can buy rebuild kits for unlike JDM Transmissions. Front side of the case is nice and clean, backside is very dirty. 270 + shipping
- Pic1
D16z6 Distributor, painted hot mexican chrome. Came out of a working setup. $60 shipped
- Pic1
94 Civic SI (d16z6) 120k Cylinder head w/ Intake manifold. Pretty good shape, came off a running setup with no problems. Pics show what it includes, TPS/IAT sensors are ok the Black sensor on the back fast idle? is broke. But everything else is pretty much there, injectors/rail etc. SOLD
- Pic1
- Pic2
I'm hoping most of this **** sells locally because I hate shipping stuff out. I gladly accept paypal, but if payment is over 100 dollars you will have to pay the extra paypal bullshit charge. (so just ad it in)
Please PM me for info
Modified by AbaZ at 1:30 AM 6/5/2004
Modified by AbaZ at 11:26 AM 6/6/2004
Modified by AbaZ at 11:28 AM 6/6/2004
Modified by AbaZ at 11:29 AM 6/6/2004
Modified by AbaZ at 11:49 AM 6/6/2004
Modified by AbaZ at 9:31 PM 6/6/2004
Modified by AbaZ at 3:02 PM 6/7/2004
Modified by AbaZ at 3:03 PM 6/7/2004
Modified by AbaZ at 11:54 PM 6/7/2004
- Pic1
- Pic1
- Pic1
- Pic2
- Pic3
- Pic1
- Pic1
- Pic2
- Pic3
- Pic1
- Pic2
- Pic1
- Pic1
- Pic2
- Pic3
- Pic1
- Pic1
- Pic1
- Pic1
- Pic2
- Pic1
- Pic2
- Pic1
- Pic1
Also keep in mind this tranny is one of the only Cable B-series tranmission you can buy rebuild kits for unlike JDM Transmissions. Front side of the case is nice and clean, backside is very dirty. 270 + shipping- Pic1
- Pic1
- Pic1
- Pic2
holy schmokes,
youre prices are suuuuuupeRgood, wish I wasnt East Coast!
bump for a good list o' stuff at good prices... dang
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbaZ »</TD></TR><TR><TD CLASS="quote">Replied to PM's
ITR block is going to be 75 shipped anywhere 48 states via UPS Ground
75 shipped! sold to me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djbutler007 »</TD></TR><TR><TD CLASS="quote">
Homos get a service charge of $825 + the 75
</TD></TR></TABLE>Homos get a service charge of $825 + the 75
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1point5CRX »</TD></TR><TR><TD CLASS="quote">did my mounts ship out?
thanks</TD></TR></TABLE>
No they didnt, I'll letcha know
ITR block finally sold..
thanks</TD></TR></TABLE>No they didnt, I'll letcha know
goldgreen90ef
Jul 17, 2008 07:50 PM
PsychoSiRex
Mar 6, 2003 05:19 AM
