What would be the best clutch/flywheel setup for the street
I'm looking for a clutch flywheel combo and with all of the options out there I'm very unsure of what to get. I want something that will be driveable but do a good job at its purpose. I can take a little discomfort but not unbearable driving around town. Would getting a quaife lsd be worth it if this car is mainly used in straight lines because If I'm getting the tranny work done I don't want to miss anything. Please give me your opinions on what would be best
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95deckedlude »</TD></TR><TR><TD CLASS="quote">it mainly depends on how much hp you are putting out. how much hp is it?</TD></TR></TABLE>
Look at his signature.
Anyway I would suggest a Excedy clutch, stage 3 off ebaymotors. LIke 220 or so. It's 6 puck and is really nice i'm sure. I just ordered there stage one clutch and have no complaints. As far as flywheels i'd go with a 12-13 pound one.
http://www.importhorizon.com for the flywheel
my car makes 198/160 before the smsp header and cat now it feels a lot more powerful. I made 198/160 with a dc header stock cat and 2.25" inch exhaust now it's 2.5' all the way back I expect to be somewhere around 215.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder »</TD></TR><TR><TD CLASS="quote">
http://www.importhorizon.com for the flywheel</TD></TR></TABLE>
that doesnt tell me **** about his hp. it could have 2hp if its not tuned correctly
backtothe topic. I would use the clutchmasters 8lb flywheel and the act hdss clutch. Thats what I have and itsvery easy on the foot andgrabs like a son of a bitch. The revs do fall a little quick but I am quick with the shifter!
not sure if this is the best but this will be my next setup.
Action Clutch 1KS
maybe a XACT Streetlite flywheel.
Clutch 101 by Rocket where i read about Action
Action Clutch 1KS
With the whp you're going to have, I would highly recommend the Quaife. I have a Phantom Grip that quit working. Don't even consider that. Without an lsd, you're going to be wheel spinning/hopping, and doing more damage to your CV joints, which are not that great to begin with.
As far as clutch/flywheel, I would consider ACT extreme pressure plate with orgainic disc. It will be very streetable, but you may have to replace the disc once a year like I have to do. As to the flywheel, I would recommend chromoly material, which will weigh 10-12 lbs. It won't warp like aluminum. ACT, Jun, and maybe some others make them.
Make sure you post the SMSP dyno after you get it installed!
d_mina
19
Sep 28, 2004 03:30 PM
