LS/Vtec wiring- what do I do? (searched)
Old Jun 4, 2004 | 10:02 AM
Slimm-rw-'s Avatar
I'm a Jackass
Default LS/Vtec wiring- what do I do? (searched)
Do I need to buy a vtec harness or can I use my 92 integra non-vtec one? Where does the vtec solenoid plug into? I'vce searched, but found nothign conclusive. thanks
Old Jun 4, 2004 | 11:03 AM
pb16b's Avatar
Default Re: LS/Vtec wiring- what do I do? (Slimm-rw-)
add wires... all depends on what head you're planning to use and which obd and which ecu
Old Jun 4, 2004 | 11:04 AM
Your Epitaph.'s Avatar
///M Power
I have a sneaking feeling that you most certainly did not search.
Old Jun 4, 2004 | 12:25 PM
Slimm-rw-'s Avatar
I'm a Jackass
Default Re: LS/Vtec wiring- what do I do? (J_D_M_9_4)
but your sneaky feeling is wrong. I most certainly did. I found plenty of wiring harnesses for sale though
Old Jun 4, 2004 | 03:39 PM
mr.beeks's Avatar
all you need is to run
wires for your vtec solenoid
your vtec oil pressure
your knock sensor....
get the pin out for the ecu you are u using
Old Jun 12, 2004 | 01:56 PM
253EK's Avatar
Default Re: LS/Vtec wiring- what do I do? (mr.beeks)
where do i get pins? i need vtec
TTT
Old Jun 13, 2004 | 01:33 PM
ghettochild's Avatar
Default Re: LS/Vtec wiring- what do I do? (253EK)
this is OBD1 pin outs
Old Jun 13, 2004 | 01:36 PM
Default Re: LS/Vtec wiring- what do I do? (ghettochild)
and this is OBD2 for 96-98 just get some ecu pins and plug them in its easy as
Old Jun 13, 2004 | 08:24 PM
Slimm-rw-'s Avatar
I'm a Jackass
oooh, sweet
jdmh22:)
11
Feb 18, 2012 08:05 PM
sedangsr
Sep 27, 2004 01:02 PM
MM's94Civic
Jun 30, 2004 08:59 PM
ThePro
Feb 5, 2003 05:42 PM
CopperSol
Apr 1, 2002 04:19 PM
