Low Fuel light
Old Jun 4, 2004 | 05:42 AM
excel88's Avatar
Default Low Fuel light
Does your guys low fuel light go on when there is still like 2 gallons left in the tank??
Because my gauge reads no fuel, my light goes on, but i can only fit 41L (10 gallons)
Old Jun 4, 2004 | 05:52 AM
hashiriya's Avatar
Default Re: Low Fuel light (excel88)
I don't think those lights are too accurate. In my 95 accord, the light came on. I immediatly filled it up and it took 16 gallons for a 17 gallon tank. but I think the light is supposed to come on with 2 gallons left.
Old Jun 4, 2004 | 05:54 AM
furious94ls's Avatar
Does it really matter? Get gas when the needle gets to E.
Must we debate this time and time again?
Old Jun 4, 2004 | 05:56 AM
excel88's Avatar
I am saying, when the needle does to E, i still have 2 gallons full in my tank..
Must you be an *** hole?
Old Jun 4, 2004 | 07:06 AM
Default Re: (excel88)
******* is one word. I don't get what your saying? What is the point of this post? Congrats you have 2 gallons left at E.
Old Jun 4, 2004 | 07:07 AM
Dawsonb17a's Avatar
New User
Default Re: (furious94ls)
If I fill up RIGHT when my light comes on I usually only get 10 1/2 gallons in there. So I usually drive about 20-30 miles further before filling up, so usually 11 1/2 gallons, or when there's almost 2 gallons left in there.
Old Jun 4, 2004 | 07:44 AM
PlastikOwl
Guest
Posts: n/a
Default Re: (Dawsonb17a)
Either way...the light comes on...you need to get gas...
Old Jun 4, 2004 | 12:23 PM
xplanetearth420x's Avatar
my fuel light doesnt even work
who needs on anyways
rod4l's Avatar
that sounds about right
Old Jun 4, 2004 | 02:32 PM
gsr415's Avatar
Default Re: Low Fuel light (rod4l)
is the g3 teg the only teg wit the low fuel light or does all the other tegs got them too like the g2 or the g1 , i know its kinda a stupid quesion
Old Jun 4, 2004 | 02:54 PM
boostinb20vtec's Avatar
I drive mine till it's on or below E, and I have never had to put more than 11 gallons and some change in it. I really wanna get some gas in a gas can and see how far it'll go before it runs out someday, but I'm too lazy
Old Jun 4, 2004 | 02:59 PM
excel88's Avatar
Im going to do it up sunday i think
Old Jun 4, 2004 | 03:02 PM
shamoo's Avatar
Will you make something up for me please?
Of course it's best to fill up......obviously.
I routinely drive over 50 miles after the light is fully on. No problems. Your tank is a 13.2 gallon tank, so you can obviously see when you fill up and only get 10-11 gallons, there's still a lot left.
Be a risk taker and drive it, y0!
Old Jun 4, 2004 | 03:16 PM
JDM PRO's Avatar
i have heard it is best for your engine to fill up no less than a 1/4 of a tank.
Old Jun 4, 2004 | 03:45 PM
excel88's Avatar
reason?
Old Jun 4, 2004 | 04:02 PM
Gerbilo's Avatar
Less pressure on the fuel pump, and in cold weather you should always keep a fair amount in the tank to reduce risk of freezing.
If you haven't noticed as well, the gas light can turn on depending on the pitch of your car, or if you take a hard turn one way or another. I forget which way is which, but turn left hard and your gas light can turn on, turn hard right and it will turn off again, it can do this for a gallon or so from what I can tell.
Did the same thing on my civic as on my integra.
rdone
Jan 5, 2015 04:01 PM
mugenracer
Jul 8, 2008 06:42 AM
SlowDown
May 16, 2007 08:44 PM
Lucas_pln
Apr 17, 2007 06:04 AM
91ED7Si
21
Mar 4, 2002 09:12 AM
