Are the radio antenna's on a del sol power?
Old Jun 4, 2004 | 01:10 AM
speshuled619's Avatar
Default Are the radio antenna's on a del sol power?
Just what the topic said, are the radio antenna's on del sol's power or are they manual. They look like the should be power but im not sure. Can anyone end my confusion?
Old Jun 4, 2004 | 01:12 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Are the radio antenna's on a del sol power? (speshuled619)
yeah they're suppose to be power. mines just stuck
Old Jun 4, 2004 | 04:40 AM
foz's Avatar
foz
There are power ones, and there are manual ones....
Mine had a broken manual one, so I replaced it with a manual one 'cuz it was cheaper, now it's just gone alltogethor .. shave it....
the car looks like an rc racer with the ant up
Old Jun 4, 2004 | 06:53 AM
skip.two's Avatar
Default Re: Are the radio antenna's on a del sol power? (foz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foz &raquo;</TD></TR><TR><TD CLASS="quote">the car looks like an rc racer with the ant up </TD></TR></TABLE>
hahaha yea it does to me, now. hm i think most of them are manual. power was an option. not sure though.
Old Jun 4, 2004 | 07:03 AM
EFbomb's Avatar
dEL SOL S - manual antenna
del sol Si - power antenna
Del Sol Vtec - power antenna
All power antennas after like 3-4 years get stuck and quit working
Old Jun 4, 2004 | 08:18 PM
Default Re: (b23eight)
Is there anyway to fix these "quit wokring" ones? what can i look for as a possibilty to fixing it? Its my girlfriends car and like to get it working. She has the Vtec model.
Old Jun 5, 2004 | 05:44 AM
foz's Avatar
foz
Default Re: (speshuled619)
easiest way to fix is to replace....
however if it's power and just doesn't move smoothly you can try a spray graphite (lubricant) put a rag behind the ant (where your spraying) and have someone sit in the car turning the radio on and off and spray it while it is raising and lowering,
I also have my replacement manual all black ant. ( you manually pull it up and down) that I'll gladly ship and send ya...
Old Jun 5, 2004 | 03:44 PM
VivaDelSol's Avatar
My Del Sol is from '96 and it still works fine!
Old Jun 5, 2004 | 04:18 PM
clm's Avatar
clm
Default Re: (VivaDelSol)
If the lubrication doesn't fix it, just get an aftermarket manual from AutoZone. They look better IMO and they're a LOT cheaper than a new power one.
JDW
Nov 28, 2009 07:56 AM
shak3yb0n3z
Aug 12, 2009 07:39 PM
reds
Sep 20, 2004 03:34 PM
Spade
23
Mar 20, 2002 09:02 PM
