Mr. clean car wash????
Works well, but the soap and the water filter need replacing often, and both are somewhat expensive for what they are. Also, be sure to use alot of soap as not alot comes out when your spraying it on.
I heard it sucks, some say they used it and it still left water spots. Do a search on here, s2ki.com, and google and I'm sure you will come up with an answer.
The Mr. Clean car wash works awsome. I washed my 2004 Graphite(Close to Black) Ram. I did everthing as directed and it turned out amazing. It looks showroom clean again. I see a bunch of people say that the end rinse only come out as a mist like spray. This is normal and how it just works. I suggest it to anyone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona »</TD></TR><TR><TD CLASS="quote">I heard it sucks, some say they used it and it still left water spots. Do a search on here, s2ki.com, and google and I'm sure you will come up with an answer.</TD></TR></TABLE>
I used it today and it worked great. If it leaves water spots, you probably didn't use it right. It looks much much cleaner than drying it off with a shamy (sp) and stuff. It was specially cooler that my girl did all the scrubbing, I was just spraying it. heh heh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue »</TD></TR><TR><TD CLASS="quote">it works well and the auto dry is great.. i dont' use the soap they give with it tho... i just use it for the water filter thingie....</TD></TR></TABLE>
I tried using it just for the rinse - it left spots. I was pissed ... I'm gonna try the soap too and see how it works.
we use somthing like the mr clean auto wash at my dealership, it works well. what its doing is filtering out the crap in water that leaves spots.
ps-PROFILES2000 that s2000 is looking hot
