JDM B16A SiR II map sensor help
Old Jun 3, 2004 | 08:38 PM
zer0.'s Avatar
Default JDM B16A SiR II map sensor help
i just put my JDM B16A SiR II in my 94 EH2,i noticed that the throttle body has no place for a map sensor.....so where does the map sensor go?
EDIT: does anyone have a good picture of the map sensor w/ vaccum lines?
Modified by zer0_2_6ixty at 9:52 PM 6/3/2004
Old Jun 3, 2004 | 08:40 PM
Cnote's Avatar
Default Re: JDM B16A SiR II map sensor help (zer0_2_6ixty)
well on the JDM motors, the MAP is placed on the firewall. So the little nipple out of the TB will go to a vacuum line that runs to the bottom of the map sensor...
Old Jun 3, 2004 | 09:00 PM
Travis.EK's Avatar
Default Re: JDM B16A SiR II map sensor help (Cnote)
I just relocated my old one onto the firewall, to the brake lines with some zip ties. worked fine.
Old Jun 4, 2004 | 10:39 AM
shogun1's Avatar
If your trying to use the MAP sensor that mounts to the top of the Throttle body, then you will have to change throttle bodies. Or else you will need to buy a MAP for that style throttle body. either way, you will need to buy one or the other. I believe either system will work but if your putting it into a OBD1 or newer vehicle, then I'd buy a throttle body. I have a used JDM one for sale if you need it, *(its OBD1 and uses the top mounted MAP sensor) Or you can buy New ones from STR, Edelbrock*(Recommended), BBK, Spoon *(Recommended), etc... If you are a JDM person, then Spoon. Hope this helps
jphil101
Apr 2, 2010 11:36 AM
SVOboy
Mar 26, 2006 11:48 AM
civichatch67
Sep 21, 2005 10:11 AM
88crxhfb16
Apr 16, 2005 05:59 PM
zerofighter777
May 27, 2002 01:43 PM
