has anyone ever put a d16z into a 91 civic?
Old Jun 3, 2004 | 08:05 PM
Oral_hyjinx's Avatar
Default has anyone ever put a d16z6 into a 91 civic?
has anyone ever had any major problems dropping a z6 into a 91 civic? anything electrical?
Old Jun 3, 2004 | 08:09 PM
BauleyCivic's Avatar
Risky Business
Default Re: has anyone ever put a d16z6 into a 91 civic? (Oral_hyjinx)
Wrong forum dinkledork.
Old Jun 3, 2004 | 08:13 PM
Patch's Avatar
Default Re: has anyone ever put a d16z6 into a 91 civic? (BauleyCivic)
Depends on whether you want to do it, or do it right.
You can just do it by using a D16A6 distributor, ECU, and an RPM activated switch for vtec.
You can do it right by converting to OBD-1 and running a stock P28.
All the mounts and mount brackets from the orignial engine need to be transferred over to the Z6, and it will bolt right in. Stock linkage and axles also.
Old Jun 3, 2004 | 08:22 PM
Default Re: has anyone ever put a d16z6 into a 91 civic? (Patch)
its already been done.. Ive swapped the engine mounts, and put my stock intake manifold. trany, and distributor on the new engine. And I purchased an rpm activated module to control the vtec... but now the engine wont fire up.
Old Jun 3, 2004 | 08:25 PM
Patch's Avatar
What model is your car? STD? DX? Si?
What kind of engine was in it?
Old Jun 3, 2004 | 08:28 PM
its an si... Im not positive what was in it, I think a d16a... but I might be wrong.
Old Jun 3, 2004 | 08:30 PM
Patch's Avatar
It should work, check your firing order. If thats correct, check your ignition timing.
Old Jun 4, 2004 | 01:05 PM
mr. carpenter's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Wrong forum dinkledork.</TD></TR></TABLE>
why is this the wrong forum? i just put one into mine and had no problems.
Old Jun 4, 2004 | 01:13 PM
Risky Business
Default Re: has anyone ever put a d16z6 into a 91 civic? (mr. carpenter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">
why is this the wrong forum? i just put one into mine and had no problems.</TD></TR></TABLE>
He originally posted it in EG.
Old Jun 4, 2004 | 01:21 PM
oh okay, i know you been around and thought maybe you were going crazy.
Modified by mr. carpenter at 11:17 PM 6/4/2004
C00kiemunstr
Oct 11, 2008 08:59 AM
kempa'sDA
Dec 18, 2006 11:54 AM
CalhounBoi
17
Oct 2, 2006 07:35 PM
B SERIES US
Feb 24, 2006 09:59 PM
srv3fender
10
Feb 28, 2005 09:48 PM
