order of screws for oil pan
Old Jun 3, 2004 | 07:57 PM
asiansgoweeee's Avatar
Default order of screws for oil pan
i believe my car is leaking oil from the oil plug. i am going to replace the gasket, plug, and washer. i heard that when putting the oil pan back on you have to put in the screws in a certain order, any clue what that order is and if there is a site that explains it step by step. i have a b16a and a 1990 civic ex if that matters at all.
Old Jun 3, 2004 | 08:29 PM
EL Vap133's Avatar
Default Re: order of screws for oil pan (asiansgoweeee)
I'm not sure about the order, but when I did mine I just tighetened every other one. No leaks or anything.
Old Jun 3, 2004 | 10:09 PM
XrcR6's Avatar
Disclaimer: You should double-check these specs. with a Helms... (you should also get one)
I believe there is a specific order outlined in the service manual... If you are pressed for time and can't order one (http://www.helminc.com) try something like starting from the middle of the pan rail and work your way outward, alternating from front to back. Also those nuts/studs and bolts don't need that much torque, I forget but its only ~9-12ft/lbs. If you don't torque them evenly then you'll end up with a leak too.
Old Jun 4, 2004 | 01:05 AM
Mr_CRX's Avatar
Default Re: order of screws for oil pan (XrcR6)
This is an image from my 94 integra manual, but I figure its the same idea for the CRX (I couldnt find it in my CRX manual). Anyways, the numbers didnt come out in the scan, but its like putting lug nuts on. Tighten in two steps in a crisscross/star pattern.
Old Jun 4, 2004 | 08:56 AM
so should i buy the book based on the car model which would be a 94 del sol or 90 integra, or look for a book on a b16a? and would i buy an oil pan gasket for a b16a or 94 del sol vtec?
Old Jun 4, 2004 | 08:57 AM
EL Vap133's Avatar
You can buy it for the Del B16 motor, or for the 99-00 Si motor.
Old Jun 4, 2004 | 12:43 PM
Default Re: order of screws for oil pan (EL Vap133)
was that a reply to the manual question or to the oil pan gasket?
Old Jun 4, 2004 | 01:52 PM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asiansgoweeee &raquo;</TD></TR><TR><TD CLASS="quote">was that a reply to the manual question or to the oil pan gasket? </TD></TR></TABLE>
Both.
Old Jun 4, 2004 | 10:03 PM
Default Re: order of screws for oil pan (kid-honda)
thanks man appreciate the help
sparkyk20eg
K Series
Aug 22, 2018 08:01 PM
yesSiReK
Sep 26, 2007 05:16 PM
Rhood
Feb 7, 2007 05:30 PM
DjTrex
Sep 24, 2005 01:40 PM
dynomax27
Oct 15, 2002 04:22 PM
