ITR differential into DB2 tranny?
i very much would like to know the same thing since i also have a DB2...sorry i don't have an answer to your question
although i have a hunch that it all b series internal trany parts are pretty interchangeable.....don't quote me on it though
You have a B17A1, right?
That has a 4.400 final drive. So if you are talking about the USDM ITR LSD, then it will fit because the USDM ITR has the same 4.400 final drive.
If you are talking about the JDM ITR LSD, it won't fit. The final drive in that car is 4.785, and not only do you need a 4.785 final drive ring gear, but also a 4.785 countershaft.
This is just talking about fitting in the LSD physically. You may or may not need to have proper shims to make sure everything fits back together.
kool168
Feb 19, 2004 06:13 AM
Black R
Mar 5, 2003 08:08 PM
