ES motor mounts
Old Jun 3, 2004 | 05:13 PM
Fly1865's Avatar
Default ES motor mounts
Ok, heres the skinny. I was thinking about buying a set of the ES motor mounts since i have to replace my rear one i was thinking hey might has well throw the insert in there since the rear one is the pita of the 2. So tell me what you think.
Old Jun 3, 2004 | 05:19 PM
satan_srv's Avatar
Default Re: ES motor mounts (Fly1865)
The rear is not needed.
My engine makes 167 ft lbs of torque and the motor did not move on the dyno with only the front mount installed
see video http://satan.higginstribe.com/nov18dyno.mov
this has been covered many times
Old Jun 3, 2004 | 06:31 PM
BB6-213's Avatar
Same here, I just have the front mount in, and the difference is amazing. No more wheel hop, and it doesn't vibrate that bad at all.
Old Jun 3, 2004 | 06:58 PM
Speedra500's Avatar
Default Re: (BB6-213)
how does removing the rear mount prevent wheel hop?
Old Jun 3, 2004 | 07:03 PM
satan_srv's Avatar
Default Re: (Speedra500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 &raquo;</TD></TR><TR><TD CLASS="quote">how does removing the rear mount prevent wheel hop?</TD></TR></TABLE>
ES mounts are just INSERTS that attach to the stock mounts. We're talking about not installing the rear INSERT as it provides unnecessary vibration on the car when the engine isnt under load
Old Jun 3, 2004 | 07:12 PM
Keith's Avatar
Default Re: (satan_srv)
The front motor mount insert will reduce majority of movement... but after installing the rear motor mount, the car does not move as much when downshifting... it feels a lot more solid...
Keith
Old Jun 3, 2004 | 08:03 PM
matix's Avatar
I have front left and right polyurethane filled,and rear urethane insert and i love it. Well worth it in my opinion. I trashed a tranny diff with stock accord ex rear mount. So the rear prelude mount with insert was first on my list.
Old Jun 3, 2004 | 10:17 PM
Daboi630's Avatar
i should be installing my front ones tomorrow. they have been sittin in my car for the longest time
Old Jun 3, 2004 | 10:48 PM
4bidden's Avatar
Default Re: (Daboi630)
http://members.***.net/4bidden/mount_install
Old Jun 3, 2004 | 10:50 PM
SUB-0 H23's Avatar
ES inserts are dope as hell
Old Jun 3, 2004 | 10:55 PM
Daboi630's Avatar
Thanks for the link Jeremy
you should have it linked on your website.
Old Jun 4, 2004 | 06:29 AM
Sephro's Avatar
yeah front only. The rear will only help if you are backing up
Old Jun 4, 2004 | 08:58 AM
h22a193's Avatar
both are most certainly needed if you want to launch without wheel hoop.
Old Jun 4, 2004 | 12:09 PM
LudeyKrus's Avatar
I think you should install both. They come as a set; they should be used as a set.
I don't really think the vibration w/ the rear is much at all.
Old Jun 6, 2004 | 08:56 PM
2000sh's Avatar
I put both mine in when i upgraded the clutch and flywheel since the tranny was off anyway.... well i love the change, and the vibration isn't bad at all.... my girl even says it makes the car feel more alive during idle...
Old Jun 7, 2004 | 01:29 AM
Saki's Avatar
Default Re: ES motor mounts (2000sh)
I had the ES mounts in my lude... It did vibrate a lot more than stock but hey whadda you expect...
Old Jun 7, 2004 | 02:51 AM
thehondaguru's Avatar
Default Re: ES motor mounts (Saki)
both are in an my peice of **** build and the motor is solid and it doesntreally vibrate.
I agree with ludy becayse they are a set why not use them!
Old Jun 7, 2004 | 05:22 AM
Daemione's Avatar
Default Re: ES motor mounts (95 lude)
FWIW, the rear inserts aren't hard to install at all. Just pull the throttle body, and you've actually got more space to work than in the front . . . .
Old Jun 7, 2004 | 05:43 AM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000sh &raquo;</TD></TR><TR><TD CLASS="quote">my girl even says it makes the car feel more alive during idle...</TD></TR></TABLE>
I bet she loves to sit on the washing machine too
hanktransam
Honda Ruckus and Scooters
May 7, 2019 11:38 AM
Lsweez
Nov 6, 2007 11:22 AM
Boner_Ben
May 29, 2007 03:21 PM
Maengelito
16
Dec 5, 2004 07:07 AM
F120man
Feb 10, 2004 11:42 AM
