clutch still slipping need advice???????
Old Jun 3, 2004 | 01:10 PM
ablack934doorcivic's Avatar
Default clutch still slipping need advice???????
anyone have advice on what could be wrong with my 93 civic had the clutch replace and about 30,000 miles later it was slipping again they said the rear main was defective and replaced the seal and clutch for free again. once again the clutch is slipping and the rear main seal is leaking. i was told could be the crank shaft bearing is worn. what do you guys think. i'm thinking of swapping in a b16a2 jdm motor if it's to much of a pain to fix. thanks
Old Jun 3, 2004 | 02:06 PM
BatuKing's Avatar
Default Re: clutch still slipping need advice??????? (ablack934doorcivic)
OK what is a crank shaft bearing? the only thing that seals the crank is the rear main seal.. if its leaking its leaking.. make sure you use a OEM honda seal.
Old Jun 3, 2004 | 03:28 PM
Default Re: clutch still slipping need advice??????? (BatuKing)
anything else it could be
Old Jun 11, 2004 | 02:14 PM
HELP
sii.
Mar 18, 2010 04:50 PM
standbackimapro
Dec 25, 2006 04:26 PM
eldorko86
Nov 7, 2005 03:18 PM
PatrickGSR94
Apr 15, 2003 09:32 PM
