B20Vtec dyno sheet
Old Jun 3, 2004 | 01:06 PM
H2nr's Avatar
Default B20Vtec dyno sheet
stock B20z shortblock, rods, pistons........
stock GSR head, cams, springs, retainers.........
stock GSR ecu with a VAFC
stock GSR intake mani, and TB
DC intake, DC 4-2-1 header, and 2.25 exhaust
we turned the Vtec on at 4600rpm and as you can see it make power until 7800rpm
Old Jun 3, 2004 | 01:28 PM
SupaFly_Honda's Avatar
Default Re: B20Vtec dyno sheet (H2nr)
damn nice numbers.
Old Jun 3, 2004 | 01:29 PM
bumb for stock parts
Old Jun 3, 2004 | 03:08 PM
rainmanEK's Avatar
big strong guy
Default Re: B20Vtec dyno sheet (SupaFly_Honda)
170whp?
Hmm....
Eric
Old Jun 3, 2004 | 03:10 PM
Rob Dizzle's Avatar
thats pretty good for a sub 2k dollar setup.
alot of people with built motors that have 5k into their money dont make that much power.
if you did a better header, intake manifold, maybe 310 injectors, plus hondata and you will have a fatter tq curve
Old Jun 3, 2004 | 03:51 PM
desert eagle's Avatar
thats a strong *** oem engine bro. hands down madd props
Old Jun 3, 2004 | 05:06 PM
7thGear's Avatar
Default Re: B20Vtec dyno sheet (B20vtec81)
crazy torque curve, i can sleep on it.
Old Jun 3, 2004 | 05:22 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: B20Vtec dyno sheet (7thGear)
That header is really holding you back. Ditch the DC and your numbers will improve even more.
Old Jun 3, 2004 | 05:56 PM
H2nr's Avatar
Default Re: B20Vtec dyno sheet (rochesterricer)
Thanks everyone, but its not my car. Its my best friends car. I am just the tuner. We wanted to see what we could get out of stock parts. Its all in a DC2 that still has AC and PS. The car runs 14.0-13.9 right now. The next round of parts will be 4-1 header and ITR cams.
PS he has been driving on this setup for over 3 years now and drag or scca races it all the time.
Old Jun 3, 2004 | 06:04 PM
H2nr's Avatar
PSS here is one of my guys turbo cars
https://honda-tech.com/zerothread?id=885048
Old Jun 4, 2004 | 09:11 AM
B20JonLee's Avatar
Default Re: B20Vtec dyno sheet (Bob-DC2)
I actually am running RC 310's with my V-AFC and do plan on a 4-1 header. I have port matched the gsr intake manifold to help it some. I am very fond of having the dual runners scince it is my daily driver the extra low end is nice. The type-R cams are what she really needs to breath at this point. Hopefully I won't have to wait too long to see what they do!
Here is a link to our local SCCA picture gallery for pics of my car running.http://www.erikandersondesigns.com/images/2004/041104-OMRSCCA/images/041104-omrscca-358.jpg
Old Jun 4, 2004 | 11:12 AM
H2nr's Avatar
Default Re: B20Vtec dyno sheet (B20JonLee)
Yes, this is B20JonLee 's dyno sheet I have posted
Old Jun 10, 2004 | 09:01 AM
B20JonLee's Avatar
No reason to wait!!! New 4-1 header on car! New dyno sheet should be posted soon. LOVE the gains. More power better tourque curve......SWEET
I am running the car this weekend in local compact class competetion at Ozark International Raceway. Hope to have new best E.T. to go with Dyno update.
Old Jun 10, 2004 | 10:41 AM
LSVTEC0WNZJ00's Avatar
I'm impressed if you really ran a 14.0 with that setup. I'd like to see a time slip personally. But if your car is doing that well being a heavy DC2 I shouldn't worry about my teg as much.
Old Jun 10, 2004 | 11:44 PM
H2nr's Avatar
Default Re: B20Vtec dyno sheet (LSVTEC0WNZJ00)
here it is
we got 11ft-lbs of tq more at 4300rpm and 6hp more after the retune. Come on 13.80s
Old Jun 11, 2004 | 03:34 AM
JCushing's Avatar
a DC2 weighs basically the same as a DA
Old Jun 15, 2004 | 03:53 PM
B20JonLee's Avatar
I personally do not possess a scanner. My buddy posted my dyno sheet for me. These are the numbers off of my slip
React: 0.5328
60 Ft: 1.9726
330Ft: 5.8305
1/8ET: 9.0376
1/8mph: 78.67
1000ET: 11.7897
1000MPH: 88.32
1/4ET: 13.9730
1/4MPH: 96.77
Helps to have a GOOD set of wrinkle walls (M/T)
Old Jun 16, 2004 | 07:30 PM
misfithamster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20JonLee &raquo;</TD></TR><TR><TD CLASS="quote">I personally do not possess a scanner. My buddy posted my dyno sheet for me. These are the numbers off of my slip
React: 0.5328
60 Ft: 1.9726
330Ft: 5.8305
1/8ET: 9.0376
1/8mph: 78.67
1000ET: 11.7897
1000MPH: 88.32
1/4ET: 13.9730
1/4MPH: 96.77
Helps to have a GOOD set of wrinkle walls (M/T) </TD></TR></TABLE>
nice time man.. i gotta get my *** to the track as well. my setup dynoed at 168 hp and 133 tq with stock internals, stock cam timing and basic bolt-ons. mines inside a gutted ef hatch.. i hope to come close to these times?
Old Jun 17, 2004 | 12:02 AM
@ries's Avatar
Default Re: B20Vtec dyno sheet (misfithamster)
Nice #'s! Glad you got more power after the re-tune
Old Jun 17, 2004 | 12:16 AM
EMO-anthony's Avatar
Default Re: B20Vtec dyno sheet (@ries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries &raquo;</TD></TR><TR><TD CLASS="quote">Nice #'s! Glad you got more power after the re-tune </TD></TR></TABLE>
Another to that!
Old Jun 17, 2004 | 01:35 AM
DutchVintec's Avatar
Damn, that's a very nice run.
But isn't your 1/4 mph a bit low for a high 13s run??
And with that pretty good 60ft should it not be possible to run a 13.7s something like that??
Nevertheless a nice timeslip, it just looks to me a little more speed should be in the car.
Old Jun 17, 2004 | 07:21 AM
MikeySpec's Avatar
Thats a sick *** A/F line!!
Old Jun 18, 2004 | 10:31 PM
B20JonLee's Avatar
Default Re: B20Vtec dyno sheet (DutchVintec)
You will find that when your 60ft times drop your time will improve but your mph will often drop as your are actually making it to the stripe quicker with less initial spin. Also do you realize we are talking about a 2750lb Integra??
da NiN3
24
Feb 28, 2011 01:30 PM
1.9crxNA
15
Sep 19, 2006 08:09 PM
carboy_honda
10
Jun 12, 2005 05:59 AM
b18c_ek
Aug 20, 2004 02:21 PM
juniordc2
Apr 9, 2002 02:29 PM
