Install problem
Old Jun 3, 2004 | 12:55 PM
ritalin
Guest
Posts: n/a
Default Install problem
Ok I decided to install a y8 intake manifold on my y7 block. I have the map and tps hooked up. Also I finally got my throttle cable hooked up right. Now i'm having problems with the 2 other sensors. The air inlet sensor and the other sensor thats mounted on the fuel rail. Right now as it sits my y7 will idle slightly above normal (1200 rpm) but when I go to give it gas it bogs unless i'm around 2k. Other than that it actually moves.
Old Jun 3, 2004 | 04:08 PM
ritalin
Guest
Posts: n/a
Default Re: Install problem (rps13 redtop)
I drove home and it runs like ****. Almost like its on 2 cylinders instead of 4. Someone help please!
Old Jun 3, 2004 | 05:42 PM
perlmeister8's Avatar
Make sure that you don't have the TPS and MAP sensor's switched around.
Old Jun 3, 2004 | 07:10 PM
ritalin
Guest
Posts: n/a
Default Re: Install problem (perlmeistere81)
Yeah I think I got the map and tps right but something is definitely wrong. I had to lengthen some wires so I wonder if I really messed it up.
Rease3
17
Jan 22, 2010 08:28 AM
HarosGSRek
Engine Management and Tuning
Jul 1, 2009 10:58 AM
Devious951
Jun 5, 2009 08:25 AM
CimorelliCRX
May 14, 2003 09:38 AM
CimorelliCRX
Feb 14, 2003 09:14 PM
