battery troubles/no start.. please help!!
Old Jun 3, 2004 | 11:28 AM
turboH22Aakkord's Avatar
Default battery troubles/no start.. please help!!
i recently did a jdm h22a swap on my 92 accord.. the car runs great and stuff.. but even before i did the swap the battery would go dead... i just thougtht it was a shitty bat. but after i did the swap i put a new bat in ... it ran great for a while.. but then it started shitting out again.. the new bat now doesn't work... i shut off the car and its dead as hell... i thought it might be the ALT.. but the alt. is new with the jdm h22a so i figured that isnt' it. could a bad starter be the prob? like to much resistance or something? any advice is welcomed .... thanks in advace!!
Old Jun 3, 2004 | 12:12 PM
Kal's Avatar
Kal
Default Re: battery troubles/no start.. please help!! (turboH22Aakkord)
maybe it's two shitty alternators lol. Check your electrical connections.
Old Jun 3, 2004 | 12:55 PM
Sephro's Avatar
Default Re: battery troubles/no start.. please help!! (Kal)
Jump it. When it is running disconnect the battery. See if the car dies. If it's still running at idle blip the throttle a little to get the RPM's up some. If the car dies then it's the alternator. If it doesn't then it's a shitty battery or you have some sort of a short somewhere. Because the car should run with out the help of the battery. Oh yeah when doing this keep things like the radio, heat/AC or any other electrical items shut off.
Old Jun 3, 2004 | 01:36 PM
RAB's Avatar
RAB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboH22Aakkord &raquo;</TD></TR><TR><TD CLASS="quote">is new with the jdm h22a so i figured that isnt' it. could a bad starter be the prob? like to much resistance or something? any advice is welcomed .... thanks in advace!!</TD></TR></TABLE>
There's no such thing as a new JDM H22A are motors coming from Japan are used. A starter start the car and has nothing to do with your battery running dead. Go through least expensive check list first.
1.) Check electrical connection that relate to battery stuff.
2.) Could an electrical device be turned on once you turn off your car for the night.
3.) Check the battery, is it old, new, can it hold a charge.
4.) Check the alternator.
Old Jun 4, 2004 | 08:33 AM
Default Re: battery troubles/no start.. please help!! (Sephro)
problem solved... the alt came with the h22a so it only had like 40 or 50 k on it.. and when we put it in.. my buddy didnt' tighen up the wire that conects to the alt.. it was all loose and carodid... cleaned it up and she runs ship shape! thanks for your help!! except for Rab who was mean... ( by new i ment... with the engine which was new to me.. the engine only had 50k or so on it.. and anything under 100k is new to me! haha )
ZappasOne
Apr 24, 2008 11:08 AM
turboH22Aakkord
Jun 4, 2004 09:26 AM
brimy311
Mar 10, 2003 03:23 PM
W.Zero
Jan 28, 2003 11:43 AM
