code 22 vtec oil pressure help
Old Jun 3, 2004 | 08:15 AM
spoolineh2's Avatar
Default code 22 vtec oil pressure help
allright I have been running my b16a for some time without any problems with vtec kicking over. But I recently had some problems with the fuse that goes to the ignition, but it was just a bad fuse so my car would not start. but I changed the fuse and now I am pulling ecu code 22, and my vtec will not kick over. any suggestions would be greatly appreciated. I would like to get this fixed fast
thanks
Old Jun 3, 2004 | 08:20 AM
spoolineh2's Avatar
Default Re: code 22 vtec oil pressure help (spoolineh2)
not vtec oil (vtec pressure valve) my bad don't flame
Old Jun 3, 2004 | 08:35 AM
0bd1_Kanobe's Avatar
What year of motor is it.This ussualy happens when the selenoid is going bad
Old Jun 3, 2004 | 10:39 AM
spoolineh2's Avatar
Default Re: (BseriesHybrid)
it's a first gen
Old Jun 3, 2004 | 11:32 AM
Sounds like a symptom of a bad selenoid
Old Jun 3, 2004 | 03:02 PM
MikeSarr_GSR's Avatar
check your oil pressure at idle. you should be able to light the solenoid into VTEC at idle, if there isnt enough oil pressure... it WONT. the solenoid is pretty uncomplicated... I am sure they can go bad... mainly from being in a crate for ages with salt water from JAPAN I bet
Old Jun 4, 2004 | 08:00 AM
spoolineh2's Avatar
Default Re: (MikeSarr_GSR)
how would i go about lighting the soliniod into vtec at idle. Or could you tell me some way to test the solinoid.
Old Jun 4, 2004 | 08:40 AM
Put direct power and ground(battery) then hear for a click. If it does not click it's bad!!!!!
Old Jun 5, 2004 | 12:35 PM
spoolineh2's Avatar
the soninoid is not bad, I put direct power onto it and it clicks over. however, I changed the oil and cheched the solinoid and the check engine light is still on. does any body know wich spots on the ecu to check for continuity between the ecu and the vtec sonlinoid. thanks for any info
Old Jun 5, 2004 | 12:36 PM
spoolineh2's Avatar
Default Re: (spoolineh2)
well it might not be reading any oil pressure would that make it so it won't kick over. And how would I go about checking that
Old Jun 10, 2004 | 02:48 PM
spoolineh2's Avatar
allright I read 0 ohms from the vtec solenoid to the ecu. and the vtec is kicking over but I am still pulling cade 22. When vtec kicks in my car immediatly bogs down andbegins to back fire. and it goes slower in vtec then when it is in lower gears. please help
Old Jun 10, 2004 | 03:09 PM
staticrex's Avatar
When have you checked the oil level last? Wait till the motor cools down and the oil settles, I had the same problem and the oil was just low. If that doesn't work have you cleaned the filter in the vtec solenoid? There is also a filter in between the whole vtec assembly and the head, you can clean both of those and that may help.
CRX91SE
Apr 3, 2012 08:40 PM
dimond21
Mar 4, 2009 09:54 AM
Totall Insane
Dec 1, 2008 09:59 AM
danteisme
Sep 26, 2004 03:19 PM
BobGnarly
May 23, 2004 05:28 PM
