Throttle cable??
Which throttle cable do i use for lsvtec with gsr throttle and str intake manifold. i've tried ls, too short, tried stock cx, too long, tried gsr perfect but don't have plastic piece that will make it fit down where the gas paddle is, so i tapped it up and zip tied it just for now. do you guys know which cable i can use to make it fit without modifying it?
what car is it??? this may help.. for my b16a2 into my 97 civic dx, luckily I had a type r thorttle bracket that come with my swap and I just orderd the type r throttle cable from honda becuase my dx one just poped on me ,it was too long also like your cx's, I think you just need a thorttle bracket since you said the GSR one is perfect
i have the complete gsr throttle cable with all parts need to work...from the throttle body to the firewall to the gas pedal.
><U>$15 shipped to your location.</U>
eg6si... do you still have your gsr throttle cable? what year is it? Does it have that little slip on plastic piece at the end part where it slips onto the gas pedal?
94allmotor
Feb 11, 2009 08:25 PM
