4040 or not??
Old Jun 3, 2004 | 03:29 AM
crx_88_si's Avatar
Default 4040 or not??
Last year I bought a rear disk conversion from a 90 CRX Si. It had everything included. Trailing arms, Control arms, Master Cyl (7/8"), and Prop Valve.
I have since then decided to just part the whole thing out as the calipers were both shot and are fairly expensive where I live (125$ EACH). Ok, on to the problem. I sold the prop valve. The buyer got it just fine but says it's stamped 2040? I've never seen another 4-wheel disk valve other then this one. Can some1 confirm something here for me!? I thought the non 4-wheel disk vakve was a 4030, so wtf is a 2040!
-Mike
Old Jun 3, 2004 | 04:26 AM
crx_88_si's Avatar
Ok.. researching this a little. Im seeing that a 2040 is the valve from a 90-91 CRX Si. Can anyone confirm this for me?
Old Jun 3, 2004 | 06:00 AM
90SICRX's Avatar
Default Re: (crx_88_si)
where can you find those numbers? I have a 90 si, i can walk out the door and tell you
Old Jun 3, 2004 | 06:02 AM
crx_88_si's Avatar
stamped onthe housin of the prop valve. on the pass side shock tower!
Old Jun 3, 2004 | 06:59 AM
90SICRX's Avatar
2040 for a 1990 crx SI
Old Jun 3, 2004 | 07:05 AM
crx_88_si's Avatar
Default Re: (90SICRX)
thank you!
Old Jun 3, 2004 | 08:52 AM
90SICRX's Avatar
Old Jun 3, 2004 | 11:42 AM
StupidSlowRSX's Avatar
91 was the only year CRX's came with all wheel disc
Old Jun 3, 2004 | 11:46 AM
90SICRX's Avatar
Default Re: (StupidSlowCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX &raquo;</TD></TR><TR><TD CLASS="quote">91 was the only year CRX's came with all wheel disc</TD></TR></TABLE>
Nope 90 si's came with all wheel disc's as well, I have the original sitcker that was in the window of the car when bought, says right on it 4 wheel disc brakes
Old Jun 3, 2004 | 02:04 PM
owned.... I never knew that..
Old Jun 3, 2004 | 06:11 PM
splinter51's Avatar
4040 is integra or big front brake car
Old Jun 5, 2004 | 07:59 AM
OneZero1010101's Avatar
My 89 si has rear discs as well, unless I've been lied to and its not a 89 lol, strange things have happened.
Old Jun 5, 2004 | 10:09 AM
hatchback_al's Avatar
Default Re: (OneZero1010101)
are their visible screws in your corner lights? if so its an 88-89
Old Jun 5, 2004 | 10:54 AM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OneZero1010101 &raquo;</TD></TR><TR><TD CLASS="quote">My 89 si has rear discs as well, unless I've been lied to and its not a 89 lol, strange things have happened.</TD></TR></TABLE>
Only ''90-'91 CRX Si's all had 4 w. discs.
If you VIN starts.... JHMED936*KS000000 it IS an '89.
JS=88
KS=89
LS=90
MS=91
Just my .02 cents
Modified by 4crx4me at 3:26 PM 6/5/2004
Old Jun 5, 2004 | 11:10 AM
B2FiNiTY's Avatar
Default Re: (4crx4me)
It must have been changed.
'89 CRX si DO NOT have rear disc.
Old Jun 5, 2004 | 11:25 AM
4crx4me's Avatar
Default Re: (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">It must have been changed.
'89 CRX si DO NOT have rear disc. </TD></TR></TABLE>
Yes you are correct. And I was wrong
ONLY 90-91 CRX Si's have rear disc. Just checked my parts manual.
Time for a post edit. Or maybe his is Canadian, my book doesn't include Canada.
You never know what weirdness you'll find in Canadian models.
pxsx
Jul 21, 2008 08:19 AM
Dr.Honda
Apr 20, 2008 08:15 PM
Viorent Grip! EG
Oct 13, 2006 09:56 AM
vtec95
May 23, 2005 08:20 AM
ExodusJKD
Jul 11, 2004 06:56 AM
