?'s about cooling/AC fans...
for the wire harnesses for the cooling fan a AC fan there are two wires : one is black and the other is blue. normally the black wire is a ground wire and the other would be the positive wire. So my question is that true with the fan wire harnesses? i just replaced both of my fans for my upcomming turbo install and want to make sure i have this correct.
if you have the voltage reversed the fans will spin backwards and will push air towards the radiator rather than sucking, though black is the standard for negative and from my experience with my 91 RS, they follow the rule.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Publius1775 »</TD></TR><TR><TD CLASS="quote">if you have the voltage reversed the fans will spin backwards and will push air towards the radiator rather than sucking, though black is the standard for negative and from my experience with my 91 RS, they follow the rule.</TD></TR></TABLE>
just wanted to confirm my pondering. thanx man!
BodyKits NW
May 22, 2003 04:44 PM
