Noise near the front suspension HELP!!!
For the last 2 weeks I've been hearing a clunkity-clunk coming from the front driver side suspension area.
I had lowered the car (Tein Flex
) about a month and a half ago.
It first started happening every know and then hear and there.
But now when ever I go over a bump it makes a clunk-clunk.
It ONLY happens whenever I go over a bump. Its not constant. If I am on a straight away and smooth pavement nothing. Any help would be appreciated.
All the ball joints appear to be a okay. Both outter tie rod ends have a little play in them but only 1 side is making the noise.
by the way its a 98 Civic EX coupe.
) about a month and a half ago.It first started happening every know and then hear and there.
I've never heard the term 'Spring Perches' before. Could someone enlighten me?
I have a camber kit but I haven't had akward tire wear on the front tires so I don't see any need in replacing that.
Bolts on the shock tower are fine.
I replaced my sway bar link with prothane kit. All rest of the bushings look okay but I will double check late today first I gotta go to bed its 430. my time.
thanks guys for helping.
this is for you.
this is for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">the perches are the two things that raise up and down and tighten together to hold the desired drop of your car.</TD></TR></TABLE>
they arent always adjustable
The pirches are fine they are real tight. I was looking around and son of a b*tch on the strut where you can adjust the dampening it appeared to be higher than the other one. I am not to sure what it would be called but it looked off. Right now I am taking the strut assembly out. Does anyone know if these can be rebuilt if that is the problem?
Thanks you guys.
Thanks you guys.
Figured it out. I'm a F*cking idiot. okay well I took the coilover all apart and looked over everything and it all looked okay I just greased up where the pillow ball mount is put it back together and when I was adjusting the the coilovers.
I noticed that the nut on the top of the strut was also moving up!! So I loosen the coilover and tighten the nut then adjusted the coilover.
To my amazement...
THE CLUNK-CLUNK went away!!! Man that was so gay I can't believe I overlooked that. Nothing appeared to be damaged from it.
The tie rods got a little play so I'll be taking those out and replacing them within the next 3 weeks.
Thanks for everyones input.
To my amazement...
lazii_boi08
Dec 8, 2007 08:09 PM
