High Nox: Does the dyno fan really matter?
Old Jun 2, 2004 | 09:37 PM
4crx4me's Avatar
Default High Nox: Does the dyno fan really matter?
I failed smog.
90 CRX Si. 180,060 miles, 100% stock, no mods, first failure.
Gas........ standard.......... reading
NOx....... 1839......... 1944 fail
HC......... 234......... 74 pass
CO........ 1.32.......... 0.48 pass
CO2................. 14. pass
O2................. .40 pass
The ref DID NOT put the dyno fan in front of car. When he did the pull, it went on automatically, but it was still on the side of the car, could this be the reason for the slightly high NOx reading?
I've read in other High Nox threads that some people say without the fan you'll get a high NOx reading.l
I don't want to start ripping the car apart and spending money needlesly, when it could just be he forgot to move the fan
Any ideas?
Old Jun 3, 2004 | 02:06 AM
Quitripin's Avatar
Default Re: High Nox: Does the dyno fan really matter? (4crx4me)
NOX is created when, when the car is being overheated, lean air/fuel mixtures, vacum leak, over advanced igintion timing and a defective EGR (exhaust gas reluctor). You might want to check them out if you cannot find out with is then your goin to have to take it to a specialist or shop who can isolate the nox with a 5 gas analizer.
Old Jun 3, 2004 | 02:54 AM
non-VTEC's Avatar
the cooling will "might" help but only a little.
you want to pass that test retard the timing a few degrees and it will pass.
Old Jun 3, 2004 | 04:49 PM
4crx4me's Avatar
Default Re: High Nox: Does the dyno fan really matter? (non-VTEC)
ttt
AMS_
Jan 18, 2013 01:18 AM
ReVeNgEd-SoN
Feb 9, 2010 04:22 AM
yz125rider21
Jun 29, 2006 04:44 PM
WTB AUTO EK
Mar 14, 2005 03:54 PM
4crx4me
Jun 2, 2004 10:50 PM
