Front wheel rattle...ARRRRRRRRRRRRRRRRRRRRRRGHHHHHHHHHHHHHH
From: 9/11/01 WTC Never Forget, United States Of America
Here is the deal I have replaced the Front UCA's/Wheelbearings and the lower ball joints.
The front wheels on my hatch rattle well the passenger side rattles more
whenever I go over a bump/pot hole or when Im driving and taking curves you can hear the wheel rattle sounds like its coming from the top of the strut mount where anybody else had/have this problem bfore if so how was it fixed?
Could it be the strut tower boots?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.RED'89 »</TD></TR><TR><TD CLASS="quote">Here is the deal I have replaced the Front UCA's/Wheelbearings and the lower ball joints.
Anybody else please
Anybody else please
I had the bearings replaced also the new upper control arms and just had the lower ball joints replaced
What HUB are you talking bout Civicsidude?
I have the exact same problem.. and its annoying me sooo much..
ive changed...
upper bll joints
lower ball joints
struts
sway bar link kit
sway bar to frame bushings
axles
inner and outer tie rods
rack assembly
next thing im thinking of is maybe upper strut mounts.. but other than that.. im running out of ideas..
sounds like the exact same thing mine is doing,
Modified by Hcivic88 at 9:14 PM 6/6/2004
ive changed...
upper bll joints
lower ball joints
struts
sway bar link kit
axles
rack assembly
Its annoying to hear that rattle drives me nuts
Im gonna replaced the strut mounts I ordered them from the dealer already
Hcivic I'll let u know what happenes after i replace the strut mounts
Anybody else have anyother ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsidude91 »</TD></TR><TR><TD CLASS="quote">the hub where the cv joints goes to</TD></TR></TABLE>
How do I check that?
There should be rubber bushings between the mount for the strut and the strut tower(frame,body) whatever. If they are worn real bad or missing there will be metal on metal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DXDOHCVTEC »</TD></TR><TR><TD CLASS="quote">
There should be rubber bushings between the mount for the strut and the strut tower(frame,body) whatever. If they are worn real bad or missing there will be metal on metal.</TD></TR></TABLE>
Yeah im gonna be replaing those this weekend
Hopefully that will fix the problem
is it just a noise? no feeling thru the wheel or chassis? a metallic "ringing" noise, that is very irregular and comes and goes? if so, i know what it is. its the hub ring that is sandwiched by the axle. it must have popped off, they come off easily and have nothing but friction keeping em in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX »</TD></TR><TR><TD CLASS="quote">do you happened to have hubcaps?</TD></TR></TABLE>
No hubcaps I have 92 GSR wheels
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">is it just a noise? no feeling thru the wheel or chassis? a metallic "ringing" noise, that is very irregular and comes and goes? if so, i know what it is. its the hub ring that is sandwiched by the axle. it must have popped off, they come off easily and have nothing but friction keeping em in there. </TD></TR></TABLE>
Is a noise plus I feel it through the chasis a steady noise
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clementine »</TD></TR><TR><TD CLASS="quote">haha i bet its just your brake shield rattling, i cut mine off and it never rattled again
, and u dont really need it either. </TD></TR></TABLE>
Is not the brake shield I feel the wheel rattle
Anybody else have anymore ideas on what it could be
, and u dont really need it either. </TD></TR></TABLE>Is not the brake shield I feel the wheel rattle
Its probably #10 in this photo. Its a nylon bushing that holds your steering rod centered in the rack. When they wear out, everytime you hit a bump sounds like you struts arent bolted down on the passenger side or something is loose on that side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxzcgasd »</TD></TR><TR><TD CLASS="quote">Its probably #10 in this photo. Its a nylon bushing that holds your steering rod centered in the rack. When they wear out, everytime you hit a bump sounds like you struts arent bolted down on the passenger side or something is loose on that side.
I say the same thing, mines doing it now and every thing else is tight. Grab the inner tierod end and try moving it up and down or side to side, it should move a good bit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorte »</TD></TR><TR><TD CLASS="quote">
I say the same thing, mines doing it now and every thing else is tight. Grab the inner tierod end and try moving it up and down or side to side, it should move a good bit.</TD></TR></TABLE>
I have Energy suspension Rack and Pinion bushings
Are those the ones to replace in other words is that the samething?
I've got a new rack too.. so that cant be the problem for me...
