Spark plug Gap size for turbo setup boosting 30lbs.
Old Jun 2, 2004 | 06:23 PM
ProjectLudeSiR's Avatar
Default Spark plug Gap size for turbo setup boosting 30lbs.
Hey guys, Im running an H22 Turbo gonna boost 30lbs. and i was wondering what would be the Gap size for for my NGK spark plugs.
Old Jun 2, 2004 | 06:36 PM
buck02's Avatar
Default Re: Spark plug Gap size for turbo setup boosting 30lbs. (ProjectLudeSiR)
i run my gsr i think at .48
Old Jun 2, 2004 | 06:39 PM
turbotypeR@SPEC's Avatar
25 Year Member
very small. probably .025-.028.whatever works
Old Jun 2, 2004 | 06:42 PM
slim9300's Avatar
Default Re: Spark plug Gap size for turbo setup boosting 30lbs. (turbotypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">very small. probably .025-.028</TD></TR></TABLE>
Old Jun 2, 2004 | 07:21 PM
m R g S r's Avatar
Default Re: Spark plug Gap size for turbo setup boosting 30lbs. (slim9300)
I ran .05 on my 6.5 psi turbo setup, and even with the msd i was blowing out the spark. I went down to .025 and it ran like a champ.
Old Jun 2, 2004 | 09:42 PM
fastludeh22's Avatar
Default Re: Spark plug Gap size for turbo setup boosting 30lbs. (m R g S r)
.028 to start, if it blows out or misses go smaller. if not you can try bigger, but that should be fine
Old Jun 2, 2004 | 10:48 PM
ndogg's Avatar
Default Re: Spark plug Gap size for turbo setup boosting 30lbs. (fastludeh22)
you will probably need heat range at least 8, maybee 9. and .020 to .028 gap.
Old Jun 3, 2004 | 07:32 AM
Default Re: Spark plug Gap size for turbo setup boosting 30lbs. (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">you will probably need heat range at least 8, maybee 9. and .020 to .028 gap.</TD></TR></TABLE>
not a 9. he may need an 8. i have h22 and zfr7f coppers worked great at 19#/450 whp
Old Jun 3, 2004 | 07:45 AM
V-SPEC 1's Avatar
I ran 9's @ 25psi running 118 fuel. Gap was .028
Old Jun 3, 2004 | 07:56 AM
PrecisionH23a's Avatar
Ding ding ding. All motors respond differently, you'll figure out what size you need when you are on the dyno.
Old Jun 3, 2004 | 07:58 AM
boosted hybrid's Avatar
As wide as possible before misfire occurs.
Old Jun 3, 2004 | 08:56 AM
Kataku2K3's Avatar
Default Re: Spark plug Gap size for turbo setup boosting 30lbs. (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">As wide as possible before misfire occurs.</TD></TR></TABLE>
Exactly, what ignition are you running? In general at that boost level we're down to ~0.024" with B series motors.
Old Jun 3, 2004 | 09:00 AM
turbo*s2k's Avatar
Sal, I'm going to run the NGK #BKR7E .028-.030
When we tuned my car at Trackmasters, Bubba threw in some NGK's with a 9 heat range, but I think that was too cold for my application. Those are gapped at .030.
Old Jun 3, 2004 | 09:06 AM
turbo*s2k's Avatar
Default Re: Spark plug Gap size for turbo setup boosting 30lbs. (TurboChrgd_Civic)
Are you going to Battle of the Imports? Let's go!
Old Jun 3, 2004 | 09:09 AM
When is it?
Old Jun 3, 2004 | 09:12 AM
USDM 4G VTEC's Avatar
30 psi on a H22??????????
once u get it done i wanna see a link to that page that shows it.....must be sick...
i guess i smell some rich kid asking for a question he should be asking the person who is building his super motor........
Old Jun 3, 2004 | 09:14 AM
turbo*s2k's Avatar
Next Saturday. It's a night event. Daryl said he'll go if I go, but I don't know if he'll run his car.
Here's the link!
https://honda-tech.com/zerothread?id=879778
Old Jun 3, 2004 | 09:16 AM
turbo*s2k's Avatar
Default Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">30 psi on a H22??????????
i guess i smell some rich kid asking for a question he should be asking the person who is building his super motor........</TD></TR></TABLE>
That's kind of harsh! He's just looking to get people's opinion's from there experience.
Old Jun 3, 2004 | 09:21 AM
Default Re: (TurboChrgd_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">
That's kind of harsh! He's just looking to get people's opinion's from there experience.</TD></TR></TABLE>
i dont mean to be an *******
the answer for his question has been given.. theres no point for me to repeat he has to gap it to ~0.028
and considering this is a webboard and the type of question... seems that he doesnt quite know how much brutal power and money involves for a 30 psi H22
if it does and can afford it.... hey mad props....... he will be one of few....
Old Jun 3, 2004 | 09:31 AM
Sketch_hs's Avatar
good luck getting that power to the ground!
Old Jun 3, 2004 | 09:48 AM
99B16Si's Avatar
for that much power i would definitely say below .024 and id probably go with a 9 series plug. it also depends alot on your ignition setup too
Old Jun 3, 2004 | 09:53 AM
GRTechnologies's Avatar
Default Re: (99B16Si)
we are at .23 @ 700whp
Old Jun 3, 2004 | 10:31 AM
Default Re: (GRTechnologies)
Hey frankie, let mo know, im down to go.
Old Jun 3, 2004 | 08:06 PM
turbo*s2k's Avatar
Default Re: (ProjectLudeSiR)
All I need is a trailer, and I'm going.... So are you in?
If worse comes to worse I'll drive...
Old Jun 3, 2004 | 09:16 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">Sal, I'm going to run the NGK #BKR7E .028-.030
