Cooling Fan Sensor 89 si
Old Jun 2, 2004 | 06:12 PM
robg2251's Avatar
Default Cooling Fan Sensor 89 si
Civic Si 1989
Fan not working.
The cooling fan sensor is a big rubber boot (near oil filter), with two wires going into it. Someone suggested disconnecting it and touching the two wires to see if the fan comes on. This would tell me if the fan sensor is out and needs replacing.
The problem, I don't know how to take the boot off. Does the entire rubber boot come off? do just the wires come out? The two wires merge right into a housing with other wires - so i'm not sure how to check this.
Any ideas?
Old Jun 2, 2004 | 06:27 PM
4DRmafia's Avatar
not quite sure what ur talking abt a boot, and try to clearfiy your self a lil man
Old Jun 2, 2004 | 06:32 PM
robg2251's Avatar
Default Re: (civicsidude91)
Yes, I didn't explain myself quite well.
In order to see if the fan works - a suggestion was made to disconnect the wires from the cooling fan sensor and touch the two wires together. If the fan comes on, then I can identify that the cooling fan sensor needs to be replaced.
I've just never done this before, and aren't really sure how to go about it.
This was one of a few suggestions that were made, when I asked why my fan wasn't working:
https://honda-tech.com/zerothre...70545
Old Jun 2, 2004 | 08:16 PM
jlicrx's Avatar
Default Re: (robg2251)
just pull the black boot and wires off - sensor has 2 pins sticking out and wires in the boot just plug over the pins
clys
Apr 11, 2011 08:08 PM
Rex89
Oct 12, 2006 12:45 PM
nashvall
Aug 11, 2004 08:55 PM
groundedcivic91
Mar 26, 2004 04:09 PM
oddcivic
Feb 8, 2002 06:38 PM
