selector shaft oil seal....help!!
I have a 90 CRX Si, 5 spd...so whatever tranny goes with that..don't know the part number...anyways...
Is it possible to change the selector shaft/shift linkage oil seal without taking the tranny apart. As in, can i slide the seal off the shaft with the linkage disconnected or do i need to take off the tranny and remove the inards. I know i cannot remove the inner selector rod without taking apart the tranny because it holds down the detent spring and ball.
Any help would be appreciated!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kamikazeCRX »</TD></TR><TR><TD CLASS="quote">Thanks for that small, yet assuring, piece of info.</TD></TR></TABLE>no problem, just take your shift linkage off, pry the old seal off and push in the new one(use a socket to punch it in place)!
cbpldc
Jul 11, 2002 04:05 AM
