passenger side window stopped working. Where should i start?
Hey, my integra passenger side window wont go down, It didnt gradually stop working just one day it just stopped. Could this be the motor? or do i need a new switch? Just need to know where to start. I know this is commen with hondas. Thanks
Most likely the motor. If you want to check, try taking out your driver side window motor and plug it in and test.
did you hit the window lock switch??? i did that once and didnt realize it..... i was checking fuses..... etc.... then my gf noticed i had hit the window lock switch....... ya im kinda slow.........
if it went out gradually, its the motor, if it went out immediatley, its more than likely the switch, or bad connection
you shoulda lubed it. take apart the door cover and have a look. check fuses and obvious just in casse. the motor couldve stressed and caused a short.l
yea it just went out and its just that one side. I havnt checked fuses yet i havnt had time. I will do that and then replace the switch, if its not that then i will just get a new motor.
