What to get for tune up
Old Jun 2, 2004 | 12:51 PM
jvcnyc's Avatar
Default What to get for tune up
I am doing the first tune up o my car this weekend and i was wondering if you guys can tell me <U>what i should get, where i should get it from.</U> I Have a 98 Civic EX 2DR with 90K. I bought this car last yr with 72K and this is the first tune up since then.
Old Jun 2, 2004 | 03:29 PM
murtnabila's Avatar
Default Re: What to get for tune up (jvcnyc)
plugs, wires, cap n rotor, pcv valve, timing belt, fuel filter, air filter (if not clean). Depending on if you willing on spending some extra money, the water pump too. What I did is buy it once w/ a lifetime warranty (I figured gonna buy it in the future so y not buy one now?) and have changed timing belt twice and changed water pump twice also!
If anything is left out I'm sure others will catch it.
Old Jun 2, 2004 | 03:32 PM
murtnabila's Avatar
Default Re: What to get for tune up (murtnabila)
oh yea, unles you are completely mechanically challenged. It's pretty simple to do yourself. The timing and water pump I would only do if you feel you are up to it or have done before. There are plenty of how-to's on timing belt replacement. But if you are not comfortable with it I would have someone else do it. Any legitimate shop should be fine.
Old Jun 2, 2004 | 06:41 PM
tylercrx's Avatar
dont forget about oil and coolant. maybe transmission fluid and check cv boots and tire pressures. also windshield washer fluid.
Old Jun 3, 2004 | 03:43 PM
jvcnyc's Avatar
any special brands recommended? any special upgrades i should do, or should i stay stock honda?
Old Jun 3, 2004 | 08:51 PM
Kevedge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jvcnyc &raquo;</TD></TR><TR><TD CLASS="quote">any special brands recommended? any special upgrades i should do, or should i stay stock honda?</TD></TR></TABLE>
OEM Hondaaa!
Old Jun 4, 2004 | 05:41 AM
EE_Chris's Avatar
Yep, def stick with OEM Honda parts, especially ignition stuff.
Cap/Rotor/Plugs/Wires
Air filter/Fuel filter/Oil filter
Timing belt/Water pump/Valve lash (also replace valve cover gasket)
Upper and lower radiator hoses/Belts/Thermostat/Coolant flush and fill
O2 sensor if the original is still in there
PCV valve - though I don't really see them going bad, its a $5 part.
And get parts online: hondaautomotiveparts.com is what I use.
Do you know maintenance history of the car?
Jaydeep
Honda Civic (2001 - 2005)
May 24, 2011 04:07 PM
mrinno
Sep 19, 2007 04:55 PM
attest53
Mar 5, 2006 08:56 AM
EXspeedyaDOTCOM
Nov 29, 2003 12:52 PM
Teggyb18b
Nov 20, 2002 05:57 PM
