code P1337 CranK Fluctuation sensor
I just got finished utting in my oil pressure gauge and then this code came on. I wasn't working anywhere near that sensor, i may have moved the wires going to it out of the dummy oil light sensor's way but hat would be it. Also took out sensor in the center of the head on the pasenger side, one wire i think it was the stock water temp sensor but i don't know. also had to take off distributer to get to that last sensor. could any of this made this code come on and if so how do i get rid of it?? Thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbarbulo »</TD></TR><TR><TD CLASS="quote">in the distributor j00</TD></TR></TABLE>
Since when? You're more than likely thinking of the CKP...position, not fluctuation.
To the poster: Since you took off the dizzy, did you reset/check timing?
vtecpoweredsol
Nov 6, 2009 11:54 AM
saywhat
Dec 5, 2004 09:41 PM
sander
Apr 25, 2003 07:46 AM
to me
