gas pedal spring
Old Jun 2, 2004 | 11:18 AM
civickiller's Avatar
Default gas pedal spring
ok i had to change my fuel line because i ripped it taking off the tank, so i had to take everything off in the interior. so im putting my pedal assembly back on, but i cant find where to put the gas pedal spring to, i see the little hole on the pedal itself but i dont know where it goes on the body
can someone please help me, a pic would be good too if anyone has there car apart enough to see it. thanks
Old Jun 2, 2004 | 11:30 AM
6MTV6's Avatar
Default Re: gas pedal spring (civickiller)
Put the spring end through the hole in the top of the pedal. Now imagine a line going from the attached spring end towards the center of your steering column, there is a small hole in the corner of the bracket behind your dash. Ta-daa!
Old Jun 2, 2004 | 01:20 PM
Default Re: gas pedal spring (Bishop4G)
dont really see anything, got a pic ?
Old Apr 3, 2007 | 08:45 AM
89efDUSTY's Avatar
back from the dead...i am having this problem and i think i have it hooked right, but i cannot tell if its because the spring is not compressed fully "if its been stretched" or if has been inserted into the wrong position...anyone picture anything...thanks
Old Apr 3, 2007 | 09:19 AM
89efDUSTY's Avatar
i know not that many people know because who the hell looks right htere but does anyone know...i have it in a bracket near the steering column
Old Apr 3, 2007 | 10:14 AM
EL Vap133's Avatar
Default Re: gas pedal spring (89efDUSTY)
Does this diagram help?
Old Apr 3, 2007 | 10:55 AM
89efDUSTY's Avatar
Default Re: gas pedal spring (EL Vap133)
[QUOTE=EL Vap133]Does this diagram help?
[QUOTE] kind of i just need to know where the other portion of the spring (part# 4) attaches...i have it mounted on a piece near the steering column but it doesnt seem right..."its mounted in like it seems an edge not made for it". This causes my idle to rise because of the freefall of the pedal and i just need to know if i have it in the righ tlocation or if the spring has just grown weak so i can pull it tighter...thanks
Old Apr 3, 2007 | 11:41 AM
89efDUSTY's Avatar
i walked to lunch bump
Old Apr 3, 2007 | 12:29 PM
89efDUSTY's Avatar
sanman000719
Aug 21, 2011 05:58 PM
Fuster_Cluck
Sep 4, 2007 04:33 PM
mr poo
Oct 15, 2006 10:55 AM
lude1888
Apr 23, 2006 06:39 PM
