In need of alignment advice
See sig for setup. It will be dropped 1.75" on Tokico Illuminas (if that matters). What I'm looking for is a good idea of what I should get for camber, caster and toe, front and rear. Obviously this is for autox, otherwise I would've posted elsewhere. This car is also my daily driver so I need some good specs that would also be good for the street. And since I haven't run on these wheels and tires yet what PSI (max 50psi) do you suggest for autoxing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">The only adjustment you will have is toe.
Set it to 1/16-1/8" toe out (total toe, left and right) and 0 in the rear.</TD></TR></TABLE>
So, .RJ, what you're saying is I should toe out 1/32-1/16" EACH SIDE or 1/16-1/8" EACH SIDE? Won't toe eat my tires? Please give me a number on camber, because looking at my wheels straight on and at the outter edge of the tires it looks like I might have a little POSITIVE camber. 0 caster? Mind you, I just got my car in November, so I haven't yet done anything alignment wise because I knew I'd be getting a setup soon enough.
1/16"-1/8" total toe out (left + right).
Not enough to eat your tires.
Thats the only adjustment you have in the chassis, everything else "is what it is". You can gain more camber by lowering the car.
Touge Monsta
Aug 1, 2008 05:02 PM
Unjockable
Jul 15, 2004 11:16 AM
MintyDip
Jun 1, 2002 07:52 AM
