Where do you guys ge Hondata basemaps?
So how good is a base map? Reason I ask is because I just ordered a the S200b and provided all the info (B18C1, 550cc injectors, 7psi, etc.) for the base map to go with it. I plan to have the car tuned as soon as the turbo set up is installed, but the closest tuner is over 150 miles from my house. So could I drive 150+ miles @ 60+ mph to the tuner on the base map??? I have been planning to trailer it.
The basemap is so you can drive it, but I would DEFINATELY stay out of boost. If this means taking back roads and your trip taking twice as long to get there, so be it. Otherwise, trailer it.
I bought my hondata off of wired speed and they burned me a custom basemap with the hondata, i would check them out, good people, my tunner fine tuned it, and im getting tuned agian today, i need more power
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">The basemap is so you can drive it, but I would DEFINATELY stay out of boost. If this means taking back roads and your trip taking twice as long to get there, so be it. Otherwise, trailer it.</TD></TR></TABLE>
The trailer it is. Thanks.
if its a base map for his set-up , why wouldnt you be able to run hard with it....
Im in the same boat except here in Germany LOL...I wanna slap on the HONDATA now and wait it out till i go back Stateside in OCT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kutsuju_SLeePER »</TD></TR><TR><TD CLASS="quote">if its a base map for his set-up , why wouldnt you be able to run hard with it....</TD></TR></TABLE>
Because it's a basemap...a base for tuning. Throwing in a basemap does not mean you are tuned, and you should drive very carefully and very limited while only on a basemap. It's really only meant to get you from your house to the tuner without having to trailer your car.
Base maps are just that. They arent tuned maps. They are not optimized for fuel or timing and when you run a map thats not optimized its not safe to push it. Just because a base map is said to be "conservative" doesnt mean you can beat the **** out of your car. Conservative usually means extra fuel an less timing which equals high EGTs if pushed hard.
From my tuner VaporTrail / Secret Services. Actually going to have him make one here soon for my tune (I am almost done with my setup).
