New Azenis compound?
Old Jun 2, 2004 | 06:58 AM
lastlude2k1se's Avatar
Default New Azenis compound?
Has anyone bought new Azenis tires this year and tracked them yet? Do you find that they wear alot faster than Azenis bought in previous years(as late as last year?). I installed my brand new Azenis this April, it's daily driven, been to one HPDE, and one auto-x. Now my fronts are really close to the indicators and seems that they may not last the whole season. Has anyone else noticed a difference in wear?
Old Jun 2, 2004 | 07:00 AM
RTW DC2R's Avatar
is your alignment possibly causing the wear?
Old Jun 2, 2004 | 07:38 AM
bus stop's Avatar
Default Re: New Azenis compound? (lastlude2k1se)
since you use azenis before.....do you feel any different? if they really wear faster.....then they should give you more grip, right ?
Old Jun 2, 2004 | 07:44 AM
Hybrid ctr's Avatar
Default Re: New Azenis compound? (whOsEvO)
Just out of curiosity; the new compound is softer now right?
Old Jun 2, 2004 | 07:54 AM
Big Phat R's Avatar
Check your alignment i.e. toe-in/camber
Old Jun 2, 2004 | 07:57 AM
Default Re: New Azenis compound? (Hybrid ctr)
My alignment is fine, I just got it done around the same time as I mounted the tires.
Actually this is my first time using Azenis, I am just comparing to my friends tires who do the same kind of driving as me(daily and track), mine just seem to be wearing out alot faster than theirs. Some people that have had a chance to compare both say they feel more grip.
Old Jun 2, 2004 | 08:05 AM
pleiades nutz's Avatar
do they have the same tread wear rating between yours and ur friends?
Old Jun 2, 2004 | 08:28 AM
Default Re: New Azenis compound? (pleiades nutz)
As far as I know they're both rated at 200 treadwear.
Old Jun 2, 2004 | 08:31 AM
B2FiNiTY's Avatar
I haven't noticed any difference from the many azenis I have gone through.
Old Jun 2, 2004 | 08:36 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: New Azenis compound? (B2FiNiTY)
me neither. im on my 4th or 5th set...
Old Jun 2, 2004 | 10:44 AM
JDMTYPER's Avatar
Default Re: New Azenis compound? (SkyeC)
I was actually thinking today that I thought I had gotten more mileage out of my most recent set of Azenis vs. my other sets. You probably just drive harder on the street then your friend does.
Old Jun 2, 2004 | 11:05 AM
Austin's Avatar
Default Re: New Azenis compound? (JDMTYPER)
A new compound and tread design is due out in the Summer of '05.
Austin
Old Jun 2, 2004 | 11:15 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: New Azenis compound? (Austin)
Sweet.
I keep thinking about switching over to the Kumho MX... but maybe not.
Old Jun 2, 2004 | 11:20 AM
Big Phat R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastlude2k1se &raquo;</TD></TR><TR><TD CLASS="quote">My alignment is fine, I just got it done around the same time as I mounted the tires.</TD></TR></TABLE>
Did you get a before/after alignment sheet? What is the front toe set at?
Just because your car goes straight doesn't mean your toe/camber are set correctly/optimally.
Too much front toe will cause premature wear of the front tires in a FWD car.
If alignment is "fine" - then it's your driving style.
Old Jun 2, 2004 | 11:33 AM
all stock's Avatar
Default Re: New Azenis compound? (Big Phat R)
i think it depends on the course setup. i've done two dates on them, dedicated tires.
hpde 1: high speed sweeping turns, few sharp low speed turns - not much tread wear,
hpde 2: many, many low speed sharp turns - not much tread wear left.
also probably depends on driving style.
Old Jun 3, 2004 | 07:54 AM
Default Re: New Azenis compound? (all stock)
You guys are probably right, it maybe just my driving style. I'm gonna get my alignment checked again just to make sure.
Thanks
Old Jun 3, 2004 | 08:22 AM
REFLUX's Avatar
stop street racing Anthony!!
damn PUNK!!
SnlpeR
Dec 3, 2007 09:32 AM
comteg396
Jan 28, 2005 04:22 PM
Essence of Chicken
23
Oct 21, 2003 08:48 AM
JeffS
16
Sep 19, 2002 10:00 AM
canuckr
38
Sep 14, 2002 10:45 PM
