car wont stall or move
Old Jun 2, 2004 | 05:04 AM
J-Spec EG's Avatar
Default car wont stall or move
Ok, i changed my cluch a weeek ago and i dont think the driver axle is in all the way. My car will not move , the rpms just jump around as does the speedo. So i figure when i put the axle back in it should be fine. But heres my real concern. . car wont stall. If i put it into gear and completely let off the clutch it will jsut continure to idle, any ideas?
Old Jun 2, 2004 | 09:51 AM
J-Spec EG's Avatar
Default Re: car wont stall or move (J-Spec EG)
i swear to god is there a ******* reason noone ever answers my questions what kind of forum is this.
Old Jun 2, 2004 | 10:38 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-Spec EG &raquo;</TD></TR><TR><TD CLASS="quote">i swear to god is there a ******* reason noone ever answers my questions what kind of forum is this.</TD></TR></TABLE>
And after searching for the few threads you've created, it becomes obvious why there are a lack of responses to your threads.
Now, do you have the axles installed and seated correctly or not? Is everything hooked up and installed?
Your lack of info and attitude need to change.
Old Jun 2, 2004 | 04:40 PM
J-Spec EG's Avatar
now see was it that difficult for you to ask that. . .i thought the axle sat in, whats the easiest way to make 100% sure the axles are in?
Old Jun 2, 2004 | 05:34 PM
EE_Chris's Avatar
Default Re: (J-Spec EG)
When I did my D series tranny, basically I heard and felt a click...there is a ring around the end of the axle that seats into something, I honestly don't know what. There was visually no gap between the tranny casing and the CV either, from what I remember.
Old Jun 2, 2004 | 09:57 PM
IVI's Avatar
IVI
Default Re: (EE_Chris)
your axle isnt in. double check your work. its definitly that.
Old Jun 3, 2004 | 07:12 AM
J-Spec EG's Avatar
alright thanks
mustang5.slow
30
Jun 3, 2007 01:17 PM
EG civic
Apr 1, 2007 05:25 AM
TylerB
18
Apr 24, 2006 06:30 PM
InfamousGSR
Apr 16, 2004 10:17 AM
Ivan
Jun 30, 2003 06:04 PM
