What would happen if...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter »</TD></TR><TR><TD CLASS="quote">it would kill all the germs in your car and the car might wince a bit.</TD></TR></TABLE>
.. or that too.
PLENTY OF GOOD THINGS WOULD COME OF IT. JUST GO DO IT
.. or that too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrX-To-Tha-Max-v2.0 »</TD></TR><TR><TD CLASS="quote">I decided to pour a full bottle of rubbing alcohol into the gas tank, next time i filled up the rex? Lol i was shaving and looking at the alcohol bottle, when i just thought of it.</TD></TR></TABLE>
Well, actually there is a method to your madness, sort of.
Denatured alcohol is the main ingredient in fuel line cleaners and Dri-gas. As it absorbs water in the fuel system and breaks down gummy deposits.
But, "rubbing alcohol" is NOT 100% pure de-natured alcohol. So I wouldn't recommend it. Rubbing alcohol contains oils and lubricants for rubbing into human skin.
Not good for fuel systems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter »</TD></TR><TR><TD CLASS="quote">everclear, shh i hear the warden coming. this will probably get locked.</TD></TR></TABLE>
Wouldn't Everclear be considered "sipping alcohol", not rubbing alcohol? LOL
And put mine in a dirty glass.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edmCRX »</TD></TR><TR><TD CLASS="quote">Ethanol as far as I know
I always thought it was Methanol and/ or Nitro Methanol.
Good info in that link. But I had heard rubbing alcohol was different than the others. Because of the added ingredients
</TD></TR></TABLE>I always thought it was Methanol and/ or Nitro Methanol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gac_gonejeepin »</TD></TR><TR><TD CLASS="quote">it's methanol.....ethanol is found in the drinking variety....isopropyl is generally the rubbing type
--gabriel</TD></TR></TABLE>
^^he is correct
When your car won't pass emissions, you can dump a bottle of de-natured alcohol into your tank and take it around the block and pass with flying colors on your next pass.
Ssshhh! Don't tell anybody.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bishop4G »</TD></TR><TR><TD CLASS="quote">When your car won't pass emissions, you can dump a bottle of de-natured alcohol into your tank and take it around the block and pass with flying colors on your next pass.
How much denatured alcohol should I put in and how much gas should be in the tank. Then how long should I drive around before going back to the smog station.... Thanks.
</TD></TR></TABLE>How much denatured alcohol should I put in and how much gas should be in the tank. Then how long should I drive around before going back to the smog station.... Thanks.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JC18 »</TD></TR><TR><TD CLASS="quote">how about a licqor(?) like vodka or beer?
Yeah I tried putting malt liquor in my car but it didnt help my emissions. I put two old english 40s in my car, should I try something higher class like hinaken or guiness?
</TD></TR></TABLE>Yeah I tried putting malt liquor in my car but it didnt help my emissions. I put two old english 40s in my car, should I try something higher class like hinaken or guiness?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rasheed »</TD></TR><TR><TD CLASS="quote">
How much denatured alcohol should I put in and how much gas should be in the tank. Then how long should I drive around before going back to the smog station.... Thanks.</TD></TR></TABLE>
When my buddy did it to his bug, he just used isopropyl rubbing alcohol. He used 2 bottles. You only want to run it long enough to start burning the alcohol. once around the block should be fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4G4Dreamindx »</TD></TR><TR><TD CLASS="quote">is this bad for the car? im not gonna try this because i live in Florida and we dont have emissions test here
i just want to know.</TD></TR></TABLE>
Not at all, it just burns much cleaner than gasoline.
I have a quick and simple question.
How come I am hearing things like the lower the octane the better for emissions yet I'm hearing that denatured alcohol works wonders but isn't it basically an octane booster ?
Also would it be better to run the lowest octane gas with denatured alcohol or the highest octane gas.
Lets just say I'm doing a science experiment.
