ECU NUMBERS, USDM or JDM
Old Jun 1, 2004 | 09:28 PM
Steemo's Avatar
Default ECU NUMBERS, USDM or JDM
Is there anyway you can tell by the numbers on an ecu that it is USDM, JDM or some other wierd ecu. Im looking to do an LS swap and I need to have a US ECU to be legit in Cali, but I dont know much about ECU's I've searched and havent found anything.
Old Jun 1, 2004 | 11:40 PM
Steemo's Avatar
Default Re: ECU NUMBERS, USDM or JDM (Steemo)
good night bump
Old Jun 2, 2004 | 07:20 AM
EF_LSVtec's Avatar
If you plan on going non obd (LS motor) on your car, I'd use a PR4 (90-91 LS) ecu. I'm not sure if they made a jdm version.
Old Jun 2, 2004 | 08:02 AM
Steemo's Avatar
Default Re: ECU NUMBERS, USDM or JDM (EF_LSVtec)
i know i need a pr4 from the 90-93 integras to go obd-0 but i was wondering if the bar code type thing on the ecu says anything about where it is from. There are some numbers right before it says pr4 on the ecu and i was wondering if they held any information or anything.
Old Jun 2, 2004 | 08:27 AM
TheWackySquirl's Avatar
The Middle 3 numbers they should be spaced in between the rest of the numbers
Old Jun 2, 2004 | 03:52 PM
Steemo's Avatar
Default Re: ECU NUMBERS, USDM or JDM (TheWackySquirl)
im not trying to find out what ecu i need i know i need a pr4 i know where to find those numbers on the ecu im asking if there is any way to find out if the numbers on the ecu (the ones before or after it says pr4) tell if its usdm or jdm.
Old Jun 3, 2004 | 03:54 PM
Steemo's Avatar
anyone...bump
Old Jun 3, 2004 | 04:16 PM
kurinto's Avatar
Well on the usdm pr4 I have it says 37820-pr4-a10 , dunno if that helps you any but bump for you either way
Old Jun 3, 2004 | 05:20 PM
StorminMatt's Avatar
Default Re: ECU NUMBERS, USDM or JDM (kurinto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurinto &raquo;</TD></TR><TR><TD CLASS="quote">Well on the usdm pr4 I have it says 37820-pr4-a10 , dunno if that helps you any but bump for you either way</TD></TR></TABLE>
But what year? 1990-1991 is white plug and 1992-1993 is gray plug. So I am sure the part numbers differ between the two.
Old Jun 3, 2004 | 05:27 PM
kurinto's Avatar
Default Re: ECU NUMBERS, USDM or JDM (StorminMatt)
its a 91
Old Jun 3, 2004 | 11:50 PM
Steemo's Avatar
good night bump
pkolaboy
Apr 15, 2008 08:31 PM
Revi
Oct 11, 2006 03:15 PM
BLK99VTECR
Jul 2, 2004 09:34 PM
